Porting PmodAD1 to the microzed board
Question asked by flatmax on Apr 3, 2014
Latest reply on Aug 14, 2014 by flatmax
Hi there,
I am trying to port the PmodAD1 reference design to the microzed board.
I can produce a bitstream which only has the axi_dma and axi_ad7476 modules, as well as the relevant axi_interconnect modules.
The bitstream loads ok ... from what I see.
I also think I have a valid dts.
The interrupts I see in Xilinx xps are : 91 and 90
So I have mapped the dts interrupts to 59 and 59 .... see the dts below.
When Linux tries to boot, it has trouble when looking for the dma :
xilinx-dma 40400000.axidma: unable to request IRQ -22
Unable to handle kernel NULL pointer dereference at virtual address 00000004
pgd = c0004000
[00000004] *pgd=00000000
Internal error: Oops: 805 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.0 #1
task: ec86d1c0 ti: ec86e000 task.ti: ec86e000
PC is at xilinx_dma_of_probe+0x60c/0x6e0
LR is at __lock_is_held+0x38/0x5c
The relevant parts of my dts look like so :
fpga_axi: fpga-axi@0 {
compatible = "simple-bus";
#address-cells = <0x1>;
#size-cells = <0x1>;
ranges;
fpga_clock: fpga_clock {
compatible = "fixed-clock";
#clock-cells = <0>;
clock-frequency = <200000000>;
axi_dma_0: axidma@40400000 {
#address-cells = <1>;
#size-cells = <1>;
#dma-cells = <1>;
compatible = "xlnx,axi-dma";
reg = <0x40400000 0x10000>;
dma-channel@40400000 {
compatible = "xlnx,axi-dma-s2mm-channel";
interrupts = <0 59 0x4>;
xlnx,datawidth = <0x40>;
xlnx,sg-length-width = <23>;
xlnx,include-dre = <0x0>;
ad_adc_0: AD7476A_1@79020000 {
compatible = "xlnx,axi-ad-adc-1.00.a";
reg = < 0x79020000 0x10000 >;
dmas = <&axi_dma_0 0>;
dma-names = "ad-adc-dma";
adc-name-id = "ad7476a";
adi,streaming-dma;
axi_dma_1: axidma@40440000 {
#size-cells = <1>;
#dma-cells = <1>;
reg = <0x40440000 0x10000>;
dma-channel@40440000 {
interrupts = <0 58 0x4>;
ad_adc_1: AD7476A_2@79040000 {
reg = < 0x79040000 0x10000 >;
dmas = <&axi_dma_1 0>;
adi,streaming-dma;
trigger: trigger@0 {
compatible = "iio-trigger-hrtimer";
Here is my mhs file :
# PORT SWs_8Bits_TRI_IO = SWs_8Bits_TRI_IO, DIR = IO, VEC = [7:0]
# PORT LEDs_8Bits_TRI_IO = LEDs_8Bits_TRI_IO, DIR = O, VEC = [7:0]
# PORT BTNs_5Bits_TRI_IO = BTNs_5Bits_TRI_IO, DIR = IO, VEC = [4:0]
PORT processing_system7_0_MIO = processing_system7_0_MIO, DIR = IO, VEC = [53:0]
PORT processing_system7_0_PS_SRSTB = processing_system7_0_PS_SRSTB, DIR = I
PORT processing_system7_0_PS_CLK = processing_system7_0_PS_CLK, DIR = I, SIGIS = CLK
PORT processing_system7_0_PS_PORB = processing_system7_0_PS_PORB, DIR = I
PORT processing_system7_0_DDR_Clk = processing_system7_0_DDR_Clk, DIR = IO, SIGIS = CLK
PORT processing_system7_0_DDR_Clk_n = processing_system7_0_DDR_Clk_n, DIR = IO, SIGIS = CLK
PORT processing_system7_0_DDR_CKE = processing_system7_0_DDR_CKE, DIR = IO
PORT processing_system7_0_DDR_CS_n = processing_system7_0_DDR_CS_n, DIR = IO
PORT processing_system7_0_DDR_RAS_n = processing_system7_0_DDR_RAS_n, DIR = IO
PORT processing_system7_0_DDR_CAS_n = processing_system7_0_DDR_CAS_n, DIR = IO
PORT processing_system7_0_DDR_WEB_pin = processing_system7_0_DDR_WEB, DIR = O
PORT processing_system7_0_DDR_BankAddr = processing_system7_0_DDR_BankAddr, DIR = IO, VEC = [2:0]
PORT processing_system7_0_DDR_Addr = processing_system7_0_DDR_Addr, DIR = IO, VEC = [14:0]
PORT processing_system7_0_DDR_ODT = processing_system7_0_DDR_ODT, DIR = IO
PORT processing_system7_0_DDR_DRSTB = processing_system7_0_DDR_DRSTB, DIR = IO, SIGIS = RST
PORT processing_system7_0_DDR_DQ = processing_system7_0_DDR_DQ, DIR = IO, VEC = [31:0]
PORT processing_system7_0_DDR_DM = processing_system7_0_DDR_DM, DIR = IO, VEC = [3:0]
PORT processing_system7_0_DDR_DQS = processing_system7_0_DDR_DQS, DIR = IO, VEC = [3:0]
PORT processing_system7_0_DDR_DQS_n = processing_system7_0_DDR_DQS_n, DIR = IO, VEC = [3:0]
PORT processing_system7_0_DDR_VRN = processing_system7_0_DDR_VRN, DIR = IO
PORT processing_system7_0_DDR_VRP = processing_system7_0_DDR_VRP, DIR = IO
PORT int_1_pin = int_1, DIR = I, SIGIS = INTERRUPT
PORT int_2_pin = int_2, DIR = I, SIGIS = INTERRUPT
PORT int_3_pin = int_3, DIR = I, SIGIS = INTERRUPT
PORT int_4_pin = int_4, DIR = I, SIGIS = INTERRUPT
PORT axi_ad7476_0_data0_i_pin = axi_ad7476_0_data0_i, DIR = I
PORT axi_ad7476_0_data1_i_pin = axi_ad7476_0_data1_i, DIR = I
PORT axi_ad7476_0_sclk_o_pin = axi_ad7476_0_sclk_o_pin, DIR = O, SIGIS = CLK
PORT axi_ad7476_0_cs_o_pin = axi_ad7476_0_cs_o_pin, DIR = O
PORT axi_ad7476_slave_0_cs_o_pin = axi_ad7476_slave_0_cs_o_pin, DIR = O
PORT axi_ad7476_slave_0_data1_i_pin = axi_ad7476_slave_0_data_1_i_pin, DIR = I
PORT axi_ad7476_slave_0_sclk_o_pin = axi_ad7476_slave_0_sclk_o_pin, DIR = O, SIGIS = CLK
PORT axi_ad7476_slave_0_data0_i_pin = axi_ad7476_slave_0_data_0_i_pin, DIR = I
BEGIN processing_system7
PARAMETER INSTANCE = processing_system7_0
PARAMETER HW_VER = 4.02.a
PARAMETER C_DDR_RAM_HIGHADDR = 0x3FFFFFFF
PARAMETER C_USE_M_AXI_GP0 = 1
PARAMETER C_EN_EMIO_CAN0 = 0
PARAMETER C_EN_EMIO_CAN1 = 0
PARAMETER C_EN_EMIO_ENET0 = 0
PARAMETER C_EN_EMIO_ENET1 = 0
PARAMETER C_EN_EMIO_I2C0 = 0
PARAMETER C_EN_EMIO_I2C1 = 0
PARAMETER C_EN_EMIO_PJTAG = 0
PARAMETER C_EN_EMIO_SDIO0 = 0
PARAMETER C_EN_EMIO_CD_SDIO0 = 0
PARAMETER C_EN_EMIO_WP_SDIO0 = 0
PARAMETER C_EN_EMIO_SDIO1 = 0
PARAMETER C_EN_EMIO_CD_SDIO1 = 0
PARAMETER C_EN_EMIO_WP_SDIO1 = 0
PARAMETER C_EN_EMIO_SPI0 = 0
PARAMETER C_EN_EMIO_SPI1 = 0
PARAMETER C_EN_EMIO_SRAM_INT = 0
PARAMETER C_EN_EMIO_TRACE = 0
PARAMETER C_EN_EMIO_TTC0 = 0
PARAMETER C_EN_EMIO_TTC1 = 0
PARAMETER C_EN_EMIO_UART0 = 0
PARAMETER C_EN_EMIO_UART1 = 0
PARAMETER C_EN_EMIO_MODEM_UART0 = 0
PARAMETER C_EN_EMIO_MODEM_UART1 = 0
PARAMETER C_EN_EMIO_WDT = 0
PARAMETER C_EMIO_GPIO_WIDTH = 64
PARAMETER C_EN_QSPI = 1
PARAMETER C_EN_SMC = 0
PARAMETER C_EN_CAN0 = 0
PARAMETER C_EN_CAN1 = 0
PARAMETER C_EN_ENET0 = 1
PARAMETER C_EN_ENET1 = 0
PARAMETER C_EN_I2C0 = 0
PARAMETER C_EN_I2C1 = 0
PARAMETER C_EN_PJTAG = 0
PARAMETER C_EN_SDIO0 = 1
PARAMETER C_EN_SDIO1 = 0
PARAMETER C_EN_SPI0 = 0
PARAMETER C_EN_SPI1 = 0
PARAMETER C_EN_TRACE = 0
PARAMETER C_EN_TTC0 = 0
PARAMETER C_EN_TTC1 = 0
PARAMETER C_EN_UART0 = 0
PARAMETER C_EN_UART1 = 1
PARAMETER C_EN_MODEM_UART0 = 0
PARAMETER C_EN_MODEM_UART1 = 0
PARAMETER C_EN_USB0 = 1
PARAMETER C_EN_USB1 = 0
PARAMETER C_EN_WDT = 0
PARAMETER C_EN_DDR = 1
PARAMETER C_EN_GPIO = 1
PARAMETER C_FCLK_CLK0_FREQ = 100000000
PARAMETER C_FCLK_CLK1_FREQ = 142857132
PARAMETER C_FCLK_CLK2_FREQ = 200000000
PARAMETER C_FCLK_CLK3_FREQ = 20000000
PARAMETER C_INTERCONNECT_S_AXI_HP1_MASTERS = axi_dma_0.M_AXI_S2MM & axi_dma_1.M_AXI_S2MM
PARAMETER C_USE_S_AXI_HP1 = 1
PARAMETER C_NUM_F2P_INTR_INPUTS = 2
BUS_INTERFACE M_AXI_GP0 = axi_interconnect_1
BUS_INTERFACE S_AXI_HP1 = axi_interconnect_3
PORT MIO = processing_system7_0_MIO
PORT PS_SRSTB = processing_system7_0_PS_SRSTB
PORT PS_CLK = processing_system7_0_PS_CLK
PORT PS_PORB = processing_system7_0_PS_PORB
PORT DDR_Clk = processing_system7_0_DDR_Clk
PORT DDR_Clk_n = processing_system7_0_DDR_Clk_n
PORT DDR_CKE = processing_system7_0_DDR_CKE
PORT DDR_CS_n = processing_system7_0_DDR_CS_n
PORT DDR_RAS_n = processing_system7_0_DDR_RAS_n
PORT DDR_CAS_n = processing_system7_0_DDR_CAS_n
PORT DDR_WEB = processing_system7_0_DDR_WEB
PORT DDR_BankAddr = processing_system7_0_DDR_BankAddr
PORT DDR_Addr = processing_system7_0_DDR_Addr
PORT DDR_ODT = processing_system7_0_DDR_ODT
PORT DDR_DRSTB = processing_system7_0_DDR_DRSTB
PORT DDR_DQ = processing_system7_0_DDR_DQ
PORT DDR_DM = processing_system7_0_DDR_DM
PORT DDR_DQS = processing_system7_0_DDR_DQS
PORT DDR_DQS_n = processing_system7_0_DDR_DQS_n
PORT DDR_VRN = processing_system7_0_DDR_VRN
PORT DDR_VRP = processing_system7_0_DDR_VRP
PORT FCLK_CLK0 = processing_system7_0_FCLK_CLK0
PORT FCLK_CLK1 = processing_system7_0_FCLK_CLK1
PORT FCLK_CLK2 = processing_system7_0_FCLK_CLK2
PORT FCLK_CLK3 = processing_system7_0_FCLK_CLK3
PORT FCLK_RESET0_N = processing_system7_0_FCLK_RESET0_N
PORT FCLK_RESET1_N = processing_system7_0_FCLK_RESET1_N
PORT M_AXI_GP0_ACLK = processing_system7_0_FCLK_CLK0
PORT S_AXI_HP1_ACLK = processing_system7_0_FCLK_CLK1
PORT IRQ_F2P = axi_dma_0_s2mm_introut & axi_dma_1_s2mm_introut
END
BEGIN axi_interconnect
PARAMETER INSTANCE = axi_interconnect_1
PARAMETER HW_VER = 1.06.a
PARAMETER C_INTERCONNECT_CONNECTIVITY_MODE = 0
PORT INTERCONNECT_ARESETN = processing_system7_0_FCLK_RESET0_N
PORT INTERCONNECT_ACLK = processing_system7_0_FCLK_CLK0
END
PARAMETER INSTANCE = axi_interconnect_3
PARAMETER C_INTERCONNECT_CONNECTIVITY_MODE = 1
PORT INTERCONNECT_ARESETN = processing_system7_0_FCLK_RESET1_N
END
BEGIN axi_dma
PARAMETER INSTANCE = axi_dma_0
PARAMETER HW_VER = 6.03.a
PARAMETER C_SG_LENGTH_WIDTH = 23
PARAMETER C_INCLUDE_MM2S = 0
PARAMETER C_INCLUDE_SG = 0
PARAMETER C_S_AXIS_S2MM_TDATA_WIDTH = 32
PARAMETER C_S2MM_BURST_SIZE = 256
PARAMETER C_GENERIC = 1
PARAMETER C_INCLUDE_S2MM_DRE = 0
PARAMETER C_INCLUDE_S2MM_SF = 1
PARAMETER C_BASEADDR = 0x40400000
PARAMETER C_HIGHADDR = 0x4040ffff
BUS_INTERFACE S_AXI_LITE = axi_interconnect_1
BUS_INTERFACE M_AXI_S2MM = axi_interconnect_3
BUS_INTERFACE S_AXIS_S2MM = axi_ad7476_0_S_AXIS_S2MM
PORT m_axi_sg_aclk = processing_system7_0_FCLK_CLK0
PORT m_axi_mm2s_aclk = processing_system7_0_FCLK_CLK0
PORT m_axi_s2mm_aclk = processing_system7_0_FCLK_CLK0
PORT s_axi_lite_aclk = processing_system7_0_FCLK_CLK0
PORT mm2s_introut = axi_dma_0_mm2s_introut
PORT s2mm_introut = axi_dma_0_s2mm_introut
END
BEGIN axi_ad7476
PARAMETER INSTANCE = axi_ad7476_0
PARAMETER HW_VER = 1.00.a
PARAMETER C_BASEADDR = 0x79020000
PARAMETER C_HIGHADDR = 0x7902ffff
BUS_INTERFACE S_AXI = axi_interconnect_1
PORT s_axi_aclk = processing_system7_0_FCLK_CLK0
PORT data_0_i = axi_ad7476_0_data0_i
PORT data_1_i = axi_ad7476_0_data1_i
PORT sclk_o = axi_ad7476_0_sclk_o_pin
PORT cs_o = axi_ad7476_0_cs_o_pin
PORT ref_clk = processing_system7_0_FCLK_CLK0
PORT rx_clk = processing_system7_0_FCLK_CLK3
PORT s_axis_s2mm_clk = processing_system7_0_FCLK_CLK0
PORT adc_start_out = axi_ad7476_ADC_START
PORT dma_start_out = axi_ad7476_DMA_START
END
BEGIN axi_dma
PARAMETER INSTANCE = axi_dma_1
PARAMETER C_BASEADDR = 0x40440000
PARAMETER C_HIGHADDR = 0x4044ffff
BUS_INTERFACE S_AXIS_S2MM = axi_ad7476_1_S_AXIS_S2MM
PORT mm2s_introut = axi_dma_1_mm2s_introut
PORT s2mm_introut = axi_dma_1_s2mm_introut
END
BEGIN axi_ad7476_slave
PARAMETER INSTANCE = axi_ad7476_slave_0
PARAMETER C_BASEADDR = 0x79040000
PARAMETER C_HIGHADDR = 0x7904ffff
PORT cs_o = axi_ad7476_slave_0_cs_o_pin
PORT data_1_i = axi_ad7476_slave_0_data_1_i_pin
PORT sclk_o = axi_ad7476_slave_0_sclk_o_pin
PORT data_0_i = axi_ad7476_slave_0_data_0_i_pin
PORT adc_start_in = axi_ad7476_ADC_START
PORT dma_start_in = axi_ad7476_DMA_START
END
Any help would be greatly appreciated.
thanks
Matt
