AD9361 No-OS API
Question asked by Paul.T. on Apr 2, 2014
Latest reply on Apr 2, 2014 by Paul.T.
Is there a sensible reason for this switching of fdd and rx2tx2 parameters in the ad9361_init() in ad9361_api.c?
/* Base Configuration */
phy->pdata->fdd = init_param->two_rx_two_tx_mode_enable;
phy->pdata->rx2tx2 = init_param->frequency_division_duplex_mode_enable;
It just looks so obviously wrong,
The initialisation of default_init_params in main.c doesn't help, since they are both enabled:
AD9361_InitParam default_init_param = {
    /* Reference Clock */
    40000000UL,    //reference_clk_rate
    1,        //two_rx_two_tx_mode_enable *** adi,2rx-2tx-mode-enable
    1,        //frequency_division_duplex_mode_enable *** adi,frequency-division-duplex-mode-enable
The AD9361_InitParams typedef suggests that the comment in the initialisation is correct, the first Base Configuration parameter is rx2tx2 enable:
typedef struct
    uint32_t    reference_clk_rate;
    uint8_t        two_rx_two_tx_mode_enable;    /* adi,2rx-2tx-mode-enable */
    uint8_t        frequency_division_duplex_mode_enable;    /* adi,frequency-division-duplex-mode-enable */
}AD9361_InitParam;
