adas code
Question asked by Loris_85 on Mar 19, 2014
Latest reply on Mar 28, 2014 by Loris_85
I've tried to send data to ADAS without much luck. Here my code, I remember I've no signal on OSC1 OSC2 pin of oscillator.
In this code, I don't use any adas function but only to make simpler the code. I send a registry read command and then a dummy byte. No answer..I use  MICROCHIP dsPIC30F3013.
#include <xc.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <p30fxxxx.h>
#include <spi.h>
#define FCY 5000000UL
#include "libpic30.h"
#define LED LATBbits.LATB9
#define LED1 LATFbits.LATF4
#define BT_RESET LATBbits.LATB1
#define ADAS_CHIP_SELECT LATBbits.LATB2 //Chip Select on RB2 pin
#define ADAS_SDI LATFbits.LATF3 //SDI on RF3 pin
#define ADAS_SDO PORTFbits.RF2 //SDO on RF2 pin
#define ADAS_DRDY PORTDbits.RD8 //   /DRDY on RD8 pin
#define ADAS_PD LATBbits.LATB7 //   /DRDY on RD8 pin
#define ADAS_RESET LATBbits.LATB8 //   /DRDY on RD8 pin
// FOSC
#pragma config FOSFPR = HS              // Oscillator (HS)
#pragma config FCKSMEN = CSW_FSCM_OFF   // Clock Switching and Monitor (Sw Disabled, Mon Disabled)
// FWDT
#pragma config FWPSB = WDTPSB_16        // WDT Prescaler B (1:16)
#pragma config FWPSA = WDTPSA_512       // WDT Prescaler A (1:512)
#pragma config WDT = WDT_OFF            // Watchdog Timer (Disabled)
// FBORPOR
#pragma config FPWRT = PWRT_OFF         // POR Timer Value (Timer Disabled)
#pragma config BODENV = BORV27          // Brown Out Voltage (2.7V)
#pragma config BOREN = PBOR_OFF         // PBOR Enable (Disabled)
#pragma config MCLRE = MCLR_EN         // Master Clear Enable
// FGS
#pragma config GWRP = GWRP_OFF          // General Code Segment Write Protect (Disabled)
#pragma config GCP = CODE_PROT_OFF      // General Segment Code Protection (Disabled)
// FICD
#pragma config ICS = ICS_PGD            // Comm Channel Select (Use PGC/EMUC and PGD/EMUD)
void init_periferiche();
void init_SPI();
//void init_ECG();
//void write_SPI (unsigned char* data_transmit,unsigned char size);
unsigned int read[4] = {0,0,0,0};
unsigned int SPI_counter = 0;
int main(void) {
/*unsigned char PACEAMPTH[4] = {0,0,0,0};
PACEAMPTH[0] = 0x07;
PACEAMPTH[1] = 0x00;
PACEAMPTH[2] = 0x00;
PACEAMPTH[3] = 0x00;
init_periferiche();
init_SPI();
LED = 1;
BT_RESET = 1;
__delay_ms(50);
SPI1STATbits.SPIEN = 0b1; // start SPI
while(1)
ADAS_CHIP_SELECT = 0;
while(SPI1STATbits.SPITBF);//txB libero? Scrivo
SPI1BUF = 0x07;
SPI1BUF = 0x00;
SPI1BUF = 0x00;
SPI1BUF = 0x00;
__delay_us(20);
ADAS_CHIP_SELECT = 1;
SPI1BUF = 0x00;
SPI1BUF = 0x00;
SPI1BUF = 0x00;
SPI1BUF = 0x00;
ReadSPI1(); //READ SPI1BUF TO CLEAR FLAGS
__delay_us(20); // to adjust time window of SCLK and CS (correct when change SCLK)
      } // while(1)
return(0);
} // MAIN
   TRISBbits.TRISB1=0; // BT_RESET
   TRISBbits.TRISB2 = 0; // Chip Select an output on RB2 TRISBbits.TRISB6=1; // BUFFER_ALIM IN ANALOG
   TRISBbits.TRISB7=0; // /PD OUT
   TRISBbits.TRISB8=0; // /RESET OUT
   TRISBbits.TRISB9=0; // LED OUT
   TRISFbits.TRISF2 = 1; //SDO an input on RF2 pin
   TRISFbits.TRISF3 = 0; //SDI an output on RF3 pin
   TRISFbits.TRISF4 = 0; // LED1 OUT
   TRISFbits.TRISF6 = 0; //SCK OUT on RF6 pin
   TRISDbits.TRISD8 = 1; //  /DRDY an input on RD8 pin
   ADAS_PD = 1; // /PD
   ADAS_RESET = 1; // /RESET
   ADAS_CHIP_SELECT = 1; //inizializzo sensore disattivato
   ADPCFG = 0xFFBF; // disable AN fucntions, on portB RB6 analog signal in
void init_SPI()
    // IPC0bits.SPI1IP = 1;
    //IEC0bits.SPI1IE = 0b0; // interrupt request enabled
    //IFS0bits.SPI1IF = 0b0; // interrupt request occurred
    SPI1STATbits.SPIEN = 0b0; // disabilito il modulo, in fase di config, configuro SCKx, SDOx, SDIx e SSx come porte seriali
    SPI1STATbits.SPISIDL = 0b0; // Continue module op in IDLE mode
    SPI1STATbits.SPIROV = 0b0; // No overflow
    SPI1CONbits.MSTEN = 0b1; // Master mode enabled
    SPI1CONbits.FRMEN = 0b0; // Framed SPI disabled
    SPI1CONbits.SPIFSD = 0b0; // Sync pulse direction output disabled
    SPI1CONbits.DISSDO = 0b0; // SDO pin controlled by the module
    SPI1CONbits.MODE16 = 0b0; // communication is byte-wide
    SPI1CONbits.SSEN = 0b0; // pin controlled by the  port function
    SPI1CONbits.SMP = 0b1; // sample phase: input data sampled at the end of data output time
    SPI1CONbits.CKE = 0b0; // SDO change on transition from idle CK state to active CK state
    SPI1CONbits.CKP = 0b1; //clockP
    SPI1CONbits.SPRE = 0b010; // 6:1
    SPI1CONbits.PPRE = 0b11; //  1:1 833 k
