Save frames to hard drive using Video Input-Output project of adsp bf561
Question asked by Lelouch on Mar 17, 2014
Latest reply on Apr 4, 2014 by Suraj
So, I want to save frames that stored in SDRAM by using Video Input-Output project of kit adsp bf561
I include 2 new files to sub project "Core A' of this project (YCbCrtoRGB.asm to convert YUV 444 format to RGB format; Create_BMP_RGB.c to create a bitmap image and saved it to computer hard drive)
I also edit the "Interrupt_Service.c" of "Core A" like this :
#include "main.h"
/***** Defines the interrupt service routines for CoreA                                                            *****/
void _YCbCrtoRGB (unsigned char input[], unsigned char out[],int N);
EX_INTERRUPT_HANDLER(PPI0_RxIsr) {
          unsigned char *Ptr, *Y, *Cb, *Cr;
          unsigned char *YCbCr;
          short *fimage;
          int i, j, k, oddfield;
          short temp;
          *pDMA1_0_IRQ_STATUS |= DMA_DONE;                    // acknowledge interrupt
          semaphore_frames_received = true;                    // signal core B that a frame was received
          ++current_in_Frame;
          current_in_Frame = (current_in_Frame) % 4;
          //          Partition the whole chunk of image read from the video decoder
          //          into Y, Cb and Cr planes
          Ptr = (unsigned char *) 0x00;
          Y = (unsigned char *) 0x0012FC00;
          Cb = (unsigned char *) 0x00195000;
          Cr = (unsigned char *) 0x001FA400;
          j = 0;                    //          Make a copy of Cb and Cr components
                                        //          and retrieve the missing pixels
          for (i = 0; i < (720*576); i += 2)
                    Y[i] = Ptr[j+1];
                    Y[i+1] = Ptr[j+3];
                    Cb[i] = Ptr[j];
                    temp = (short) Ptr[j] + (short) Ptr[j+4];
                    Cb[i+1] = (unsigned char) (temp >> 1);
                    Cr[i] = Ptr[j+2];
                    temp = (short) Ptr[j+2] + (short) Ptr[j+6];
                    Cr[i+1] = (unsigned char) (temp >> 1);
                    j += 4;
          //          The image, at this point, is interlaced (i.e Odd field on top,
          //          even field below)
          //          We form back the image here as a whole!
          YCbCr = (unsigned char *) 0x00;
          Ptr = (unsigned char *) 0x0012FC00;
          oddfield = 1;
          j = 0;
          k = 720*288;
          for (i = 0; i < (720*576*3); i += 3)
                    if ((i%2160) == 0)
                              oddfield ^= 1;
                    if (oddfield == 0)
                              YCbCr[i] = Y[j];
                              YCbCr[i+1] = Cb[j];
                              YCbCr[i+2] = Cr[j];
                              j++;
                    if (oddfield == 1)
                              YCbCr[i] = Y[k];
                              YCbCr[i+1] = Cb[k];
                              YCbCr[i+2] = Cr[k];
                              k++;
          /*          Do your image processing here          */
//          Convert to color RGB image        //
_YCbCrtoRGB (YCbCr, Ptr, (720*576*3));
           unsigned int line,t,n,iByte,
           Width1=720,
           Height1=576;
           n=0;
                    unsigned char *data_temp;
                    data_temp = (unsigned char *) 0x0025F800;
                    for (line=Height1; line> 0; line--){
            t=3*(line-1)*Width1;
            for(iByte=0; iByte< 3*Width1; iByte++){
                *(data_temp+n)=*(Ptr+t+iByte);
                n++;
    //Write BMP file
    create_BMP_RGB(720,576,data_temp);
EX_EXCEPTION_HANDLER(ex_handler_coreA) {
          while(1);
I can already save the image to the hard drive, but it's something like this http://i.imgur.com/KSfZdjT.png
I use the same method for Video Input project for kit adsp bf533, and the image I get is perfect.
Can anyone tell me where did I go wrong.
