How to add InitCode into Uboot?
Question asked by EvanQiu on Mar 13, 2014
Latest reply on Mar 14, 2014 by EvanQiu
     I have a problem in handing external watchdog reset.
     I use u-boot-2013.07-2013R1 for my bf512 board (with external SPI-Flash, external watchdog).The problem is I have not enough time to reset external watchdog when running int Uboot, although I add loop_wd_reset(as follow ,external watchdog WDI pin is PF5) in start.s file.
     I think the problem is default SPI0 baudrate(config in OTP) is too low, I measured time by Oscilloscope between Power up and execute loop_wd_reset is 2.6s .But my external watchdog timeout is 0.9s~2s. How Can I solve the problem.
     I used "initcode + standalone application" mode is OK in VDSP environment, Now I want to "Uboot+ application" mode, how can I add initcode to Uboot? Help me, Please...
arch/blackfin/cpu/start.s
ENTRY(_start)
          /* Set our initial stack to L1 scratch space */
          sp.l = LO(L1_SRAM_SCRATCH_END - 20);
          sp.h = HI(L1_SRAM_SCRATCH_END - 20);
          /* Optimization register tricks: keep a base value in the
           * reserved P registers so we use the load/store with an
           * offset syntax.  R0 = [P5 + <constant>];
           *   P4 - system MMR base
           *   P5 - core MMR base
#ifdef CONFIG_HW_WATCHDOG
          p4.l = 0;
          p4.h = HI(SYSMMR_BASE);
#endif
          p5.l = 0;
          p5.h = HI(COREMMR_BASE);
          /* Program the watchdog with default timeout of ~5 seconds.
           * That should be long enough to bootstrap ourselves up and
           * then the common u-boot code can take over.
          r1 = WDDIS;
# ifdef __ADSPBF60x__
          [p4 + (WDOG_CTL - SYSMMR_BASE)] = r1;
# else
          W[p4 + (WDOG_CTL - SYSMMR_BASE)] = r1;
# endif
          SSYNC;
          r0 = 0;
          r0.h = HI(MSEC_TO_SCLK(CONFIG_WATCHDOG_TIMEOUT_MSECS));
          [p4 + (WDOG_CNT - SYSMMR_BASE)] = r0;
          SSYNC;
          r1 = WDEN;
          /* fire up the watchdog - R0.L above needs to be 0x0000 */
# else
# endif
          SSYNC;
#endif
#ifdef CONFIG_EXT_WATCHDOG
    /* set port f function enable register to GPIO (not peripheral)
    p0.l = lo(PORTF_FER);
    p0.h = hi(PORTF_FER);
    r0.h = 0x0000;
    r0.l = 0x0000;
    w[p0] = r0;
    /* set port f direction register to enable some GPIO as output,
    remaining are input */
    p0.l = lo(PORTFIO_DIR);
    p0.h = hi(PORTFIO_DIR);
    r0.h = 0x0000;
    r0.l = 0xFFFF;
    w[p0] = r0;
    ssync;
    /* set port f clear register */
    p0.l = lo(PORTFIO_CLEAR);
    p0.h = hi(PORTFIO_CLEAR);
    r0.l = 0xFFFF;
    w[p0] = r0;
    ssync;
    /* set port f input enable register to enable input drivers of
    some GPIOs */
    p0.l = lo(PORTFIO_INEN);
    p0.h = hi(PORTFIO_INEN);
    r0.h = 0x0000;
    r0.l = 0x0000;
    w[p0] = r0;
    ssync;
    /* set port f polarity register */
    p0.l = lo(PORTFIO_POLAR);
    p0.h = hi(PORTFIO_POLAR);
    r0 = 0x00000;
    w[p0] = r0;
    ssync;
    r1 = 10;
loop_wd_reset:
    /* set port f set register */
    p0.l = lo(PORTFIO_SET);
    p0.h = hi(PORTFIO_SET);
    r0.l = 0xFFFF;
    w[p0] = r0;
    ssync;
    NOP;
    NOP;
    NOP;
    NOP;
    NOP;
    r0.l = 0xFFFF;
    w[p0] = r0;
    ssync;
    NOP;
    NOP;
    NOP;
    cc = r1;
    r2 = 1;
    r1 = r1 - r2;
          if cc jump loop_wd_reset;
#endif
/* Turn on the serial for debugging the init process */
serial_early_init
serial_early_set_baud
