ADAU1701 I2C communication with mcu
Question asked by op-electronics on Mar 11, 2014
Latest reply on Mar 23, 2014 by Yagami
i'm new to SigmaDSP devices and to DSP in general. I have the ADAU1701 evaluation board and i'd like to control parameters data through a microcontroller via I2C. As microcontroller i'm using an ATmega328 and i'm writing code in the Arduino environment to keep things simple. The board which hosts the ATmega328 is a self-made, it runs from 3.3V  and i'm using a standard library named Wire http://arduino.cc/en/reference/wire#.Ux82Uc4z2YN
The problem is that i can't write anything to the ADAU1701 and actually i have no clue where to address the issue. On the hardware side i have SDA and SCL connected together on both boards at VDD level with pull-up resistors. I can see both clock and data when tracking with my oscilloscope.
The source code in Arduino is the following:
#include <Wire.h>
void setup()
Wire.begin();
void loop()
  Wire.beginTransmission(0x68);
  Wire.write(0x00);
  Wire.write(0x00);
  Wire.write(0x00);
  Wire.write(0x00);
  Wire.write(0x00);
  Wire.write(0xFF);
  Wire.endTransmission();
  Wire.write(0x00);
  Wire.write(0x00);
  Wire.write(0x00);
  Wire.write(0x00);
  Wire.write(0x06);
  Wire.write(0xD4);
  Wire.write(0x00);
  Wire.write(0x01);
  Wire.write(0x00);
  Wire.write(0x00);
  Wire.write(0x00);
  Wire.write(0x00);
I'm just trying to turn off a sine tone which has the following data (as exported from Sigma Studio):
Safeload Write
Time:  17:27:46 - 160ms
IC:  IC 1
Cell Name:  Sine Wave
Param Name:  sin_lookupAlg19401mask
Param Address:  0x0000
Param Value:  255
Bytes:  4
Param Data: 0x00,     0x00,     0x00,     0xFF
Safeload Write
IC:  IC 1
Param Name:  sin_lookupAlg19401increment
Param Address:  0x0001
Param Value:  0.000208377838134766
Bytes:  4
Param Data: 0x00,     0x00,     0x06,     0xD4
Safeload Write
IC:  IC 1
Param Name:  sin_lookupAlg19401ison
Param Address:  0x0002
Param Value:  0
Bytes:  4
Param Data: 0x00,     0x00,     0x00,     0x00
Can you help?
Thank you!
Omar
