ADG904
Question asked by FreddyS on Mar 11, 2014
Latest reply on Mar 11, 2014 by EricC
I have a technical question on ADG904 RF switch.
We wish to use it as analog switch for single frequency clipped sine-wave TCXO selection (from 10MHz to 100MHz).
The problem is that we can’t load the TCXO for more than 10pF + 10K ohm and therefore we can’t load the switch output by 50 Ohm, only 10K (resistive)/10pF or more (actually it goes to another chip with high impedance input).
The question is – can we use this switch with high impedance output instead the regular usage as RF switch with 50 Ohm output?
Note: No use of wide band signal, only single frequency clock.
Data sheet link: http://www.analog.com/static/imported-files/data_sheets/ADG904_904R.pdf
Thanks
