ground loop with HDMI & VGA both connecte
Question asked by HankZ on Feb 26, 2014
Latest reply on Feb 28, 2014 by lopihyilfrtuky4e
Here is the situation; We are using the ADV7513 HDMI driver chip and the ADV7125 VGA driver chip.
If we connect both outputs to the same monitor the HDMI image has a "speckle" pattern, particularly in areas of high or low brightness (please see images attached)
When we disconnect the VGA cable the problem goes away.
As this appears to be a ground loop issue I attempted to isolate the VGA ground with a small resistor and was able to go as low as 3.9 ohms and found that the problem would be corrected, I do not want to place low ohm resistors in the ground of the VGA.
