No video output from ADV7513
Question asked by Smilence on Feb 26, 2014
Latest reply on Mar 4, 2014 by MikeOC
I met some problems in using ADV7513 in my design.
The condition is as following:
Input data: YCbCr 4:2:2 format,
                8bit color depth, embedded Sync,
                and ASP is 16:9, clock 74.25MHz.
                NO Audio data.
And the Data pin connection:
               Y[7:0]-->D[23:16],
               CbCr[7:0]-->D[15:8]
               NO H, V, DE.
According to the PROGRAMMING GUIDE, I think the InputID should be 2, and Style is 3.
let's consider a sepcific situation, the input video is 1080_60i
While, I expect the output format is RGB 4:4:4, DVI mode.
Now, when powering up the thip, the HPD state(0x42[6]) is HIGH.
Then, I start configure the registers referring to SECTION 3 - QUICK START GUIDE(p14) of the GUIDE.
Here are registers and value that I configured according to my conditon.
Address          Value
0x41[6]          0b0          //Power up circuit.
0x98                             //fixed registers setting.
0x9a
0x9c
0x9d
0xa2
0xa3
0xe0
0xf9          //values as Table 14  Fixed Registers That Must Be Set (Main Map)
//Video input format
0x15[3:0]     0b0010      //Video Format ID = 2
0x16[5:4]     0b11          //Input Color Depth for 4:2:2, 11 = 8 bit
0x16[3:2]     0b11          //Video Input Style, 11 = style 3
0x17[1]        0b1           //Aspect ratio of input video, 16x9 = 0b1
//Video output set
0x16[7]        0b0           //Output Format, 0 for 4:4:4
0x16[0]        0b0           //Output Color Space Selection, 0 = RGB
0x55[6:5]     0b00          //Output format - this should be written when 0x16[7:6], 00 = RGB.
                                   (PS:0x16[6] is reserved 0)
0x17[2]        0b1            //4:2:2 to 4:4:4 Up Conversion Method, 1 = use first order interpolation
0x56[5:0]     0b101010     //Picture Aspect Ratio, 10 = 16:9; Active Format Aspect Ratio, 1010 = 16:9 (center)
                                   (PS: I'm not sure the line above is needed)
0xAF[1]        0b0            //for DVI mode.
//HDCP NOT USED.
//Color Space Convert
0x18
0x2f                         //values referring to Table 32  HDTV YCbCr (Limited Range) to RGB (Limited Range)
//DE Generation
0x17[0]      0b1          //Enable DE Generator
0x35
0x3a                         //Values referring to Table 26  Register Settings for DE Generation
//H, V Sync generation
0x17[6:5]       0b00     //Vsync Polarity, Hsync Polarity
0x30
0x34                         //Values referring to Table 28  Register Settings for Embedded Sync Processing
                              (PS: H, V sync. adjustment is not used)
//end
I'v tried for several days, but there is no video signal on display(NO SIGNAL, not black green).
FYI.
(1) 0x9e[4] = 0b1, PLL was locked.
     0x3e = 0x14, that means Input VIC Detected was 000101** = VIC#5: 1080i-60, 16:9, which is exactly the input format.
(2) I read out all values of whole register, no error.
(3) I checked the TMDS TCLK+/- signal, and the wave is as the picture shows.
     Its frequency is about 74.25MHz, with an average voltage around 3.0V
(4) And voltage of other Txn+/- pins are around 3.0V. As another 2 picture shows.
(5) The display only supports up to HDMI 1.3.
(6) The schematic of this part is attached.
