I2C slave read issue with ADuC7023
Question asked by nsolanki on Feb 25, 2014
Latest reply on Mar 3, 2014 by nsolanki
Setup:
  • ADuC7023 Interrupt based ADI I2C slave sample code running on the ADuC7023 custom prototype board
  • Bit-bang I2C master code running on the ADuC7021 Eval Kit
  • Hardware is tested. Ground on the both board tied. I2C cables are short. Waveform looks nice. Pulls ups are 4.7 K
Codes:
ADI sample I2C slave code for the ADuC7023
#include <aduc7023.h>
// Bit Definitions
#define BIT0  0x01
#define BIT1  0x02
#define BIT2  0x04
#define BIT3  0x08
#define BIT4  0x10
#define BIT5  0x20
#define BIT6  0x40
#define BIT7  0x80
#define BIT8  0x100
#define BIT9  0x200
#define BIT10 0x400
#define BIT11 0x800
#define BIT12 0x1000
#define BIT13 0x2000
#define BIT14 0x4000
#define BIT15 0x8000
#define BIT16 0x10000
unsigned char szStoreData[] = {0x55, 0x55, 0x55, 0x55, 0x55, 0x55};    // Array to send to Slave
unsigned char ucStoreCount = 0;          // Array index variable for szStoreData[]
unsigned int uiTest = 0;
int main(void)
    POWKEY1 = 0x01;                        // Configure CPU Clock for 41.78MHz, CD=0
     POWCON = 0x00;
     POWKEY2 = 0xF4;
    POWKEY3 = 0x76;                         // Enable PWM, SPI, I2C0, I2C1 Peripherals with 41.78MHz clock
    POWCON1 = 0x924;
    POWKEY4 = 0xB1;
    // Configure P0.4 and P0.5 for I2C mode
    GP0CON |= 0x00110000;                // Only write to bits 4/5
    I2C0SCON = BIT0                       // Enable I2C Slave + Enable Rx interrupt +
            + BIT9 + BIT10              // Enable Rx interrupt + Enable Tx interrupt +
            + BIT8;                        // Enable "Stop-after-Start-Detected" IRQ.
    I2C0ID0  = 0xA0;                    // Configure Slave's I2C network address
    I2C0FSTA = BIT8;                    // Flush Slave Tx FIFO
    I2C0FSTA &= ~BIT8;
    uiTest = I2C0SCON;
    IRQEN = BIT9;                         // Enable I2C0 Slave interrupts
    ucStoreCount = 0;
    while (1)
void IRQ_Handler(void) __irq
    unsigned long IRQSTATUS = 0;
    unsigned int I2CSSTATUS = 0;
    IRQSTATUS = IRQSTA;                       // Read off IRQSTA register
    if ((IRQSTATUS & BIT9) == BIT9)        //If I2C Slave interrupt source
       I2CSSTATUS = I2C0SSTA;
       if ((I2CSSTATUS & BIT2) == BIT2) // If I2C Master Tx IRQ
            if (ucStoreCount < 6)        // Have max 6 bytes been sent?
                I2C0STX = szStoreData[ucStoreCount++];     // Load Tx buffer
       if ((I2CSSTATUS & BIT3) == BIT3) // If I2C Master Rx IRQ
            if (ucStoreCount < 6)        // Have max 6 bytes been received?
                szStoreData[ucStoreCount] = I2C0SRX;  // Read Rx buffer
                ucStoreCount++;
       if ((I2CSSTATUS & BIT10) == BIT10)// If I2C Stop after Start condition detected IRQ
            ucStoreCount = 0;            // Reset counter Array pointer.
            I2C0FSTA &= ~BIT8;
       if ((I2CSSTATUS & BIT13) == BIT13) // If I2C Repeated Start detected IRQ
            I2C0FSTA &= ~BIT8;
Bit-Bang I2C code for ADuc7021:
//P1.1 is configured for SDA
#define SDA0_enable(state)  GP1DAT|=0x02000000;GP1DAT&=0xFFFDFFFF;              //dir-out op-low
#define SDA0_set(state)     ((state?(GP1DAT&=0xFDFFFFFF):(GP1DAT|=0x02000000)))
#define SDA0_get()          ((GP1DAT&0x02)?1:0)
//P1.0 is configured for SCL
#define SCL0_enable(state)  GP1DAT|=0x01000000;GP1DAT&=0xFFFEFFFF;              //dir-out op-low
#define SCL0_set(state)     ((state?(GP1DAT&=0xFEFFFFFF):(GP1DAT|=0x01000000)))
void i2c_delay(void)
   u_int_8 i;
   for (i = 5; i; i--);
void i2c_enable (u_int_8 port, u_int_8 enable)
   switch (port) {
   case 0:
       // port 0
       SDA0_enable(enable);
       SDA0_set(1);
       SCL0_enable(enable);
       SCL0_set(1);
       break;
   default:
       // unknown port
       break;
   i2c_stop(port);
void i2c_start (u_int_8 port)
*  assumes SDA, SCL = 1
*  leaves SDA, SCL = 0
   switch (port) {
   case 0:
       // set SDA and SCL high just in case
       SDA0_set(1);
       i2c_delay();
       SCL0_set(1);
       i2c_delay();
       // start conditions are a falling edge on SDA while SCL is high
       SDA0_set(0);
       i2c_delay();
       SCL0_set(0);
       i2c_delay();
       break;
   default:
       // unknown port
       break;
void i2c_stop (u_int_8 port)
*  assumes SDA = 1, SCL = 0
*  leaves SDA, SCL = 1
   switch (port) {
   case 0:
       // set SCL low just in case
       SCL0_set(0);
       i2c_delay();
       // stop conditions are a rising edge on SDA while SCL is high
       SDA0_set(0);
       i2c_delay();
       SCL0_set(1);
       i2c_delay();
       SDA0_set(1);
       i2c_delay();
       break;
   default:
       // unknown port
       break;
u_int_8 i2c_putbyte (u_int_8 port, u_int_8 data)
*  leaves SDA = 1, SCL = 0
   u_int_8 i;
   switch (port) {
   case 0:
       // clock out bits
       for (i = 8; i>0; i--) {
           // put data on the line
           SDA0_set(data&0x80);
           data<<=1;
           i2c_delay();
           // clock
           SCL0_set(1);
           i2c_delay();
           SCL0_set(0);
           i2c_delay();
           // release the line
           SDA0_set(1);
           i2c_delay();
       // get ack/nack
       SCL0_set(1);
       i2c_delay();
       i = SDA0_get();
       SCL0_set(0);
       i2c_delay();
       return i;
   default:
       break;
   return 0;
u_int_8 i2c_getbyte (u_int_8 port, u_int_8 ack)
   u_int_8 i;
   u_int_8 data = 0;
   switch (port) {
   case 0:
       // clock out bits
           // unconditionally release SDA, just in case
           SDA0_set(1);
           i2c_delay();
           SCL0_set(1);
           i2c_delay();
           data<<=1;
           data |= SDA0_get();
           SCL0_set(0);
           i2c_delay();
       // set ack/nack
       if (ack)
           SDA0_set(0); // ack
       else
           SDA0_set(1); // nack
       i2c_delay();
       SCL0_set(1);
       i2c_delay();
       SCL0_set(0);
       i2c_delay();
       // release SDA
       SDA0_set(1);
       i2c_delay();
       // return received byte
       return data;
   default:
       break;
   return 0;
int main (void){
     //This sets the clock for the ARM
     SystemClockSetup(F_41_78_MHZ,MODE_ACTIVE);
     //i2c Write works
     i2c_start(0);
     i2c_putbyte(0, 0xA0);
     i2c_putbyte(0, 0xB1);
     i2c_putbyte(0, 0xC1);
     i2c_putbyte(0, 0xD1);
     i2c_stop(0);
     while(1){     //This doesn't work I2C slave read
         i2c_start(0);
         i2c_putbyte(0,0xA1);
         rx_byte[0] = i2c_getbyte(0,1);
         rx_byte[1] = i2c_getbyte(0,1);
         rx_byte[2] = i2c_getbyte(0,1);
         rx_byte[3] = i2c_getbyte(0,1);
         i2c_stop(0);
          i2c_delay(0);
          i2c_delay(0);     //break point is here.
Issues:
When I ran the above code in the ADuC7021, it doesn't read reliably from the slave i2c of ADuC7023. Its reading alternate between correct values and 0xff. e.g. first time array output rx_byte = [0xB1, 0XC1, 0xD1, 0xE1], second time rx_byte = [0xFF, 0XFF, 0xFF, 0xFF], third time array output rx_byte = [0xB1, 0XC1, 0xD1, 0xE1], forth time rx_byte = [0xFF, 0XFF, 0xFF, 0xFF] ........repeats
So no reliable read.
Observation:
  • When I look on the scope waveform looks fines and waveform corresponds to the data above.
Is there any solution or way around this one? I checked the Errata for ADuc7023 i2c slave but nothing.
Any help is appreciated.
nsolanki
