BF506F how to syncronize Timer to generate PWM
Question asked by marco55 on Feb 21, 2014
Latest reply on Mar 24, 2014 by Suraj
I have a problem with timers on BF506F.
I acquire a square wave using a general purpose input (PG13) for rising egde interrupt and TACI2 for falling edge interrupt.
The acquired waveform has a frequency between 30 and 60 KHz.
I want to generate a PWM signal with period equal to half period of the acquired square wave, and programmable width.
For this purpose I'm tryng to use TIMER3 configured in PWM_OUT, PULSE_HI and PERIOD_CNT.
I enable TIMER3 at the rising edge interrupt.
I have two other timers to toggle the state of a GP-OUT to generate a sqauare wave delayed from the acquired one. I use TIMER0 and TIMER1 in single pulse generation for this purpose: timer0 enabled in rise edge interrupt and timer1 enabled in falling edge interrupt.
How can I syncronize the PWM generated atTMR3 pin with the rising edge of the acquired square wave?
I am tring to disable TIMER3 at TIMER1 interrupt (that always happens in the second half-period of the acquired square wave), but sometimes I notice that in this way the TMR3 level is lowered even if the pulse of PWM is not completed, while I read in the manual that it should complete the current waveform.
these are my interrupts:
////IVG07 - PortG Interrupt A
EX_INTERRUPT_HANDLER(RiseCaptureEntry)
    *pTIMER_ENABLE = TIMEN0 | TIMEN3;
    //Interrupt Assertion
    *pPORTGIO_CLEAR = SE2000_DSP2_REFERENCE_IN;
////IVG09 - TIMER2 Interrupt
EX_INTERRUPT_HANDLER(FallCaptureEntry)
    *pTIMER_ENABLE = TIMEN1;
    *pTIMER_STATUS = TIMIL2;
////IVG11 - TIMER0 Interrupt
EX_REENTRANT_HANDLER(RiseDelayEntry)
    *pPORTGIO_SET = SE2000_DSP2_DELAYED_OUT;
    *pTIMER0_WIDTH = DelayTab[DelayID];
    *pTIMER_STATUS = TIMIL0;
////IVG12 - TIMER1 Interrupt
EX_REENTRANT_HANDLER(FallDelayEntry)
    *pPORTGIO_CLEAR = SE2000_DSP2_DELAYED_OUT;
    *pTIMER1_WIDTH = DelayTab[DelayID];
    *pTIMER_STATUS |= TIMIL1;
    *pTIMER_DISABLE = TIMDIS3;
Any suggestion?
Thanks
Marco
