gpio-addr-flash: probe of gpio-addr-flash.0 failed with error -22
Question asked by jkadin on Feb 20, 2014
Latest reply on Feb 24, 2014 by jkadin
Please bear with me I am new to the Blackfin and uCLinux but have dove in head first because I am taking over an existing project.  Lucky me.
I was able to get the gpio assisted flash working well in u-boot. erase, protect, and flread all work perfectly, cp works well writing to flash, but can't toggle the gpio when reading the flash, but flread takes care of that.
I think I am doing everything correctly, but you know how one little mistake can cause issues, I am usually pretty good at fixing this stuff, but this one has me asking for help,
Below is my MTD partition setup.  I have the Kernel options for GPIO Addressing setup and added in a coding error to make sure  the partitioning I made below is being compiled.
#if defined(CONFIG_MTD_GPIO_ADDR) || defined(CONFIG_MTD_GPIO_ADDR_MODULE)
static struct mtd_partition ezbrd_partitions[] = {
        .name       = "bootloader(nor)",
        .size       = 0x50000,
        .offset     = 0,
        .name       = "linux kernel(nor)",
        .size       = 0x760000,            // 0x1C0000 - org
        .offset     = MTDPART_OFS_APPEND,
        .name       = "file system(nor)",
        .size       = MTDPART_SIZ_FULL,
static struct physmap_flash_data ezbrd_flash_data = {
    .width      = 2,                // 16 bit
    .parts      = ezbrd_partitions,
    .nr_parts   = ARRAY_SIZE(ezbrd_partitions),
static unsigned ezbrd_flash_gpios[] = { GPIO_PG9 };
static struct resource ezbrd_flash_resource[] = {
        /*.name  = "cfi_probe",*/
        .start = 0x20000000,
        .end   = 0x207fffff,
        .flags = IORESOURCE_MEM,
        .start = (unsigned long)ezbrd_flash_gpios,
        .end   = ARRAY_SIZE(ezbrd_flash_gpios),
        .flags = IORESOURCE_IRQ,
static struct platform_device ezbrd_flash_device = {
    .name          = "gpio-addr-flash",
    .id            = 0,
    .dev = {
        .platform_data = &ezbrd_flash_data,
    .num_resources = 1,
    .resource      = &ezbrd_flash_resource,
#else //GPIO Assist
I get the probe error and no partitioning happens and no mtd's are created.
I searched like crazy for error -22 and cant find it so that is why I am asking for help.
Thanks in advance.
Jeff
U-Boot 2011.09 (ADI-2011R1) (Feb 20 2014 - 06:34:10)
CPU:   ADSP bf526-0.2 (Detected Rev: 0.2) (parallel flash boot)
Board: ADI BF526 ML Ctrl-Board board
       Support: JKadin@harman.com
Clock: VCO: 400 MHz, Core: 400 MHz, System: 100 MHz
RAM:   32 MiB
Flash: 8 MiB
In:    serial
Out:   serial
Err:   serial
KGDB:  [on serial] ready
EUP STBY: gpio: PG11 (27) set to 1
CPLD Reset: gpio: PG0 (16) set to 1 - 0 - 1
Net:   bfin_mac
Hit any key to stop autoboot:  0
Done.
..... done
Protected 5 sectors
## Booting kernel from Legacy Image at 01000000 ...
   Image Name:   bf527-2.6.34.7-ADI-2010R1ml52
   Created:      2014-02-20  19:24:59 UTC
   Image Type:   Blackfin Linux Kernel Image (gzip compressed)
   Data Size:    3605659 Bytes = 3.4 MiB
   Load Address: 00001000
   Entry Point:  0026e680
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... OK
Starting Kernel at = 0026e680
console [ttyBF0] enabled, bootconsole disabled
Calibrating delay loop... 796.67 BogoMIPS (lpj=1593344)
Mount-cache hash table entries: 512
Blackfin Scratchpad data SRAM: 4 KB
Blackfin L1 Data A SRAM: 16 KB (16 KB free)
Blackfin L1 Data B SRAM: 16 KB (16 KB free)
Blackfin L1 Instruction SRAM: 48 KB (42 KB free)
NET: Registered protocol family 16
Blackfin DMA Controller
ezbrd_init(): registering device resources
bio: create slab <bio-0> at 0
SCSI subsystem initialized
spi spi0.5: Warning: SPI CPHA not set: Slave Select not under software control!
See Documentation/blackfin/bfin-spi-notes.txt
bfin-spi bfin-spi.0: Blackfin on-chip SPI Controller Driver, Version 1.0, regs_base@ffc00500, dma channel@7
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
i2c-bfin-twi i2c-bfin-twi.0: Blackfin BF5xx on-chip I2C TWI Contoller, regs_base@ffc01400
musb_hdrc: version 6.0, musb-dma, host, debug=0
musb_hdrc musb_hdrc.0: MUSB HDRC host driver
musb_hdrc musb_hdrc.0: new USB bus registered, assigned bus number 1
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 2.6.34.7-ADI-2010R1ml52 musb-hcd
usb usb1: SerialNumber: musb_hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
musb_hdrc musb_hdrc.0: USB Host mode controller at ffc03800 using DMA, IRQ 59
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
NTFS driver 2.1.29 [Flags: R/W DEBUG].
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
JFFS2: default compression mode: priority
msgmni has been set to 48
io scheduler noop registered (default)
bfin-otp: initialized
bfin-uart: Blackfin serial driver
bfin-uart.0: ttyBF0 at MMIO 0xffc00400 (irq = 29) is a BFIN-UART
bfin-uart.1: ttyBF1 at MMIO 0xffc02000 (irq = 31) is a BFIN-UART
brd: module loaded
GPIO_PG10 granted
GPIO_PG10 Direction set as input
bfin-gpio: GPIO 26 is already reserved by BFIN-GPIO! (Documentation/blackfin/bfin-gpio-notes.txt)
IRQ for FP_HOST or GPIO_PG10 registered
GPIO_PG5 granted
GPIO_PG5 Direction set as input
bfin-gpio: GPIO 21 is already reserved by BFIN-GPIO! (Documentation/blackfin/bfin-gpio-notes.txt)
IRQ for CPLD_CPU or GPIO_PG5 registered
ml52_irq: gpio_request() - GPIO_PH10 - TrigIn success
ml52_irq: gpio_direction_input() - GPIO_PH10 - TrigIn success
bfin-gpio: GPIO 42 is already reserved by BFIN-GPIO! (Documentation/blackfin/bfin-gpio-notes.txt)
ml52_irq: request_irq() - GPIO_PH10 - TrigIn success
bfin_mii_bus: probed
bfin_mac: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, irq=-1, mdc_clk=2500000Hz(mdc_div=19)@sclk=100MHz)
bfin_mac bfin_mac.0: Blackfin on-chip Ethernet MAC driver, Version 1.1
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
bfin-wdt: initialized: timeout=20 sec (nowayout=0)
TCP cubic registered
dma_alloc_init: dma_page @ 0x016ad000 - 256 pages at 0x01f00000
