Problem with overflow
Question asked by BenChr on Jul 8, 2010
Latest reply on Jul 16, 2010 by AndreasL
I have encountered a problem with overflow. It can be seen on the picture with the flat tops.
It should have looked like the picture with the sharp tops.
The contexts is this: I am doing speechrecognition and need to calculate cepstrum coefficients of input speech:
Matlab code: Cepstrum = real(ifft(log(abs(fft(x)))));
So far I have made...
1) fft with the rfft_fr16 function,
2) abs with the cabs_fr16 function
3) Then i needed to do the log. BUT i could only find a floating point version of this one? Does a fract16 version exist?
   i could´nt find one - therefore i used the fr16_to_float function and used the logf function.
4) Everything untill this point has given quite accurate results, but then I had to convert from float_to_fr16 to be able to use the
    ifft_fr16 function. Here is my problem.
5) Because the floating point values are higher (on the tops and lower in the valleys) than +1 and -1 it overflows! I know that I probably need to divide the log(fft) with some factor and then convert, but I also want to have a nice precision when doing the ifft afterwards.
Should I loop through the log(fft) output and find the highest value and divide everything with this value, so that it is normalized to [-1 1]?
Then I could use static scaling on the ifft afterwards! Is there a more efficient way to do the normalization?
By the way: This discussion is only posted here.
Thank you
Benjamin
Here is a snippet of my code:
#define NUMPOINTS 256
complex_fract16 w[NUMPOINTS];    //twiddle sequence
complex_fract16 fftout[NUMPOINTS];
int block_exponent;
int n = NUMPOINTS;
float fft_scaled[NUMPOINTS];
float log_of_fft[NUMPOINTS];
//Make w twiddle table for FFT once.
    twidfftrad2_fr16(w, n);
void cepstrum_test(const fract16 samples256[]) {
    //cepstrum = real(ifft(log(abs(fft(x)))));
    int i = 0;
    //FFT
    rfft_fr16(samples256, fftout, w, 1, NUMPOINTS, &block_exponent, 2);
    float scaling_fft = ldexpf(1.0F,block_exponent);
    for(i=0;i<NUMPOINTS;i++) //Tak abs(fft) and scale fft and take logarithm and convert back to fr16:
        fft_scaled[i] = fr16_to_float(cabs_fr16(fftout[i]))*scaling_fft; // WOULD IT BE MORE EFFICIENT TO SHIFT THE FR16 INSTEAD OF MULTIPLYING        // WITH THE SCALING FACTOR IN THE FLOATING POINT DOMAIN?
        log_of_fft[i] = logf(fft_scaled[i]);
        fftout[i].re = float_to_fr16(log_of_fft[i]); //HERE IS THE PROBLEM.
        fftout[i].im = 0;
