AD9643 PCORE for AD-FMCOMMS1-EBZ Questions
Question asked by kcfarleysw on Feb 10, 2014
Latest reply on Feb 13, 2014 by rejeesh
Engineer Zone:
I have the following questions about AD9643 PCORE:
1) What is the rate of adc_clk in ax_ad9643.v ? Is it 250 Mhz?
2) What is the rate of the dma_clk ? Is it 125 Mhz?
3) What is the format of data from axi_ad9643_if? Is it two samples per adc clock[250 Mhz]?
4) What is the format of data going into dma_core?
5) Please explain following code: lines 280 to 302 of axi_ad9643.v
always@(posedge adc_clk) begin
     adc_data_cnt <= adc_data_cnt + 1'b1;
     case ({adc_enabl_b_s, adc_enable_a_s})
         2'b11: begin //Both I and Q
             adc_valid <= ....
             adc_data <= {adc_channel_data_b_s, adc_channel_data_a_s, adc_data[63:32]};
         end
         I don't understand what concatenating adc_data[63:32] into adc_data is accomplishing?
         adc_data[63:32] isn't being set any where else? Is it just stuffing zeros to lower 32 bits?
6) Please explain axi_ad9643_if.v and ddr[I assume double data rate] operation. I am a little confused.
    Is it getting two samples every clock at 250Mhz? How is it demuxing into a stream that the dma can handle?
5) Please explaing how the dma_core operates. What is the dma_start,dma_stream,dma_count used for? How is that different from
the dma data?
Ken Farley
