BF609 processor core stall ( possibly anomaly 16000032 ? )
Question asked by Rudstone on Feb 10, 2014
Latest reply on Feb 19, 2014 by StuartS
I've been getting a complete processor stall in my BF609 application, when the stall has occured ( visible as all data on the RS232 port stops ), if a pause the application witht he debugger the location is always in the UARTStatusHandler routine of the supplied uart driver.  Specifcally its at the read of the UART_STAT register.
StatRegValue = ADI_ANOM_16000030_READ32(&pDevice->pUARTRegs->UART_STAT);
static uint32_t adi_anom_16000030_read32(volatile const uint32_t * mmr) {
  /* Performs a 32-bit MMR read while interrupts are disabled. */
  uint32_t imsk;
  uint32_t mmrContents;
  imsk = cli();  /* clear interrupts */
  mmrContents = *mmr;
  sti(imsk);     /* restore interrupts */
  return mmrContents;
} /* adi_anom_16000030_read32 */
from disassembler
R0 = [ P1 + 0x34 ] ;
R0 += 4 ;
[ FP - 36 ] = R0 ;
CLI R0 ;
[ FP - 4 ] = R0 ;
[ FP - 12 ] = R0 ;
mmrContents = *mmr;
P1 = [ FP - 36 ] ;
R0 = [ P1 ] ;  // stalls on this instruction
[ FP - 8 ] = R0 ;
R0 = [ FP - 12 ] ;
[ FP + 0x10 ] = R0 ;
STI R0 ;
return mmrContents;
R0 = [ FP - 8 ] ;
Once stalled the SEQSTATs NSPECABT flag is set, and the application can the be unstalled by unpausing.
This behaviour only occures if I have Data Cache Enabled and in Write Through mode ( it does not appear to happen in Write Back ), and that the Stack is in L3 cachable memory.
If I move the stack to non cached L3 all appears to work fine.
System is CCES version 1.0.3.0 ( all updates applied )
BF609 silicon revision 1.0 running on Avnet Finboard.
Imported FreeRTOS OS
running Uart task to echo characters no other drivers required to produce the issue.
I believe this to be anomaly 16000032 - Core Reads of System MMRs May Cause the Core to Hang:
Any commets on this?
Is putting the Stack in a cachable region an issue otherwise. ( Setting the system stack to L3 in the system.svc editor puts it in a bank 2 which is defaulted to cachable ).
For now I will ensure the RTOS puts the stacks in uncached memory.
Thanks in advance.
