Help with Audio: ADV7511 Xilinx Evaluation Board Ref Design
Question asked by bitscream on Feb 6, 2014
Latest reply on Apr 10, 2014 by DragosB
I am trying to implement this.
http://wiki.analog.com/resources/fpga/xilinx/kc705/adv7511?force_rev=1#running_demo_sdk_program
I have downloaded the HDL Ref Design Zip and the no-OS Software Zip for Zedboard.
Before building the project using the provided library files and Source files, I was trying to run the evaluate demo ( .bat) file for the Zedboard.
I can see the static image ( the video data) and also change the resolution. But I cannot hear any audio output.
Is there something I am not executing? Does the demo file include any audio data?
I can see it says "un-mute" video and audio.
Any help with this is appreciated. I can provide you with more data based on your request.
The following is the EDID data on Tera Term.
  ADI HDMI Trasmitter Application Ver R1.1.1
  HDMI-TX:  ADV7511 Rev 0x14
  Created:  Oct 23 2013 At 14:48:08
To change the video resolution press:
  '0' - 640x480;  '1' - 800x600;  '2' - 1024x768; '3' - 1280x720
  '4' - 1360x768; '5' - 1600x900; '6' - 1920x1080.
Mute audio and video.
APP: Driver Enabled
HPD changed to HI
MSEN changed to HI
A new EDID segment was read.
HDMI device.
------------------------- EDID BLOCK 0 -------------------------
Edid Version 1.3
Mon Timing:
    Pixel clock = 74.25 MHz
    H Active    = 1280
    V Active    = 720
    Progressive
    No stereo
    Separate sync = 3
    +ve VSync
    +ve HSync
Mon Timing:
    Pixel clock = 27.0 MHz
    H Active    = 720
    V Active    = 480
    Progressive
    No stereo
    Separate sync = 3
    -ve Vsync
    -ve HSync
Mon Name:   LCD TV
Mon Freq:
    Min V Freq = 57 Hz
    Max V Freq = 63 Hz
    Min H Freq = 15 KHz
    Max H Freq = 49 KHz
Edid extensions blocks: 1
========================= EDID BLOCK 1 =========================
CEA extension block revision 3
Underscan=No  Audio=Yes  YCbCr4:4:4=Yes  YCbCr4:2:2=Yes
Data block collection information:
    Video data block
         VIC=4
         VIC=3
         VIC=2
         VIC=5
         VIC=6
         VIC=7
         VIC=1
    Audio data block
       Format Code          = 1 (Linear PCM)
        Max. No. of Channels= 2
        Sampling Freq. (KHz)= 32  44.1  48
        Length (bits)       = 16  20  24
       Format Code          = 2 (AC-3)
        Max. No. of Channels= 6
        Max. Bit Rate       = 640 KHz
    Speaker allocation data block
       0x01
       0x00
       0x00
    VSDB data block
       Max TMDS clock = 150 MHz
       Video Latency is 0x16 , Audio Latency is 0x16
       Interlaced Video Latency is 0x26 , Interlaced Audio Latency is 0x26
SPA location is at 0x9B, SPA = 1.0.0.0
Mon Timing:
    H Active    = 720
    V Active    = 480
    Progressive
    No stereo
    Separate sync = 3
    -ve Vsync
    -ve HSync
Mon Timing:
    H Active    = 1920
    V Active    = 540
    Interlaced
    No stereo
    Separate sync = 3
    +ve VSync
    +ve HSync
Mon Timing:
    H Active    = 1440
    V Active    = 240
    Interlaced
    No stereo
    Separate sync = 3
    -ve Vsync
    -ve HSync
Mon Timing:
    H Active    = 1440
    V Active    = 240
    Interlaced
    No stereo
    Separate sync = 3
    -ve Vsync
    -ve HSync
Man String:
########################### EDID END ###########################
APP: Changed system mode to Transmitter
Un-mute audio and video.
Resolution was changed to 1024x768
Resolution was changed to 1280x720
Resolution was changed to 1360x768
Resolution was changed to 1600x900
Resolution was changed to 1920x1080
Resolution was changed to 640x480
Resolution was changed to 800x600
Thank you,
Varun
