ADV7604 STDI not locking for 1024 x 2048
Question asked by ppg on Feb 5, 2014
Latest reply on Feb 11, 2014 by PaulS
I am using ADV7604 and inputting the following resolution over DVI input.
1024x2048@56
Horizontal active          1024
Vertical active                    2048
refresh                              56.56 Hz
clk                              128.00 MHz
hfront porch                    32
vfront porch                    26
hback porch                    16
vback porch                    3
hsync width                    16
vsync width                    3
ADV7604 doesn't lock to the resolution and I see CP Map, Address 0xB1, [7] (CH1_STDI_DVALID Standard Identification Data Valid for channel 1 Read Back) to toggle between 0 and 1.
Any ideas if there are any registers that need to be programmed?
Are there any limitations on min or max pixels per line, or no. of lines in ADV7604 that we need to look out for?
I have a board with ADV7612 and when I feed it with the same source and resolution, it works just fine. I have tried this with 3 different sources and always see the same issue.
Thanks
