RMS-DC converter AD8436 single supply questions
Question asked by MrChip on Jan 28, 2014
Latest reply on Feb 25, 2014 by MrChip
I have studied the datasheet for the AD8436 RMS-DC converter quite a bit, but there are some things I cannot figure out when using it with a single supply. In the example Vcc = +5V, GND = 0V
1. To what is the output DC-voltage (OUT-pin) referenced?
a. Can I supply what ever voltage I want at OGND as the voltage I want it referenced to (for instance 0V) ?
b. Or must it be "real" ground = 0V or half supply = Vcc/2?
2. When using single supply and want to use a gain >1  with the input buffer, I believe there is something fishy with the data sheet. According to the explanations for the eval board, page 19, it seems that the amplification resistors connected to IBUFIN- would terminate in ground (=0V in this case). I guess the input opamp would rail-out because of this?
    a. Should the resistors terminate in IGND instead?
     b. ..and would it even work? - the IGND is not a very stiff voltage source as it is supplied with a two 100kOhm voltage divider.
     c. Can I supply IGND myself at ~Vcc/2, or would it introduce other problems, even if it is a good source?
3. Capacitor choice for the RMS pin - would an electrolyte be fine here? Even if very small signals < 1mV is used.
Any help would be most appreciated!
Regards
/John
