PCG SPORT
Question asked by DLi9 on Jan 27, 2014
Latest reply on Feb 11, 2014 by Jithul_Janardhanan
I am currently using the block based talkthrough example for ADSP21369 clocked at CCLK of 332MHz. When I use the internal clock and frame sync for SPORT at max speed, everything works perfectly, however when I change to PCG (Following the programming model external input pin), the clock and frame sync has a delay half of the time and some how the data being transmitted has additional random values (usually very high but has no specific pattern). I was wondering if there was any reason for it. (the trasmit chain buffer uses the TCB rotational buffer copied from block based talkthrough
Code:
=========================SRU===========================
void SRU_init(void)
          // PCG connections
          SRU(LOW, PBEN20_I);
          SRU(DAI_PB20_O, PCG_EXTA_I);
          SRU(PCG_CLKA_O, SPORT1_CLK_I);
     SRU(PCG_FSA_O, SPORT1_FS_I);
     SRU (HIGH, PBEN19_I);
          SRU (PCG_CLKA_O, DAI_PB19_I);
          SRU (HIGH, PBEN17_I);
          SRU (PCG_FSA_O, DAI_PB17_I);
          // ADC data to SPORT1
          SRU (LOW, PBEN14_I);
          SRU (DAI_PB14_O, SPORT1_DA_I);
======================Register Config====================================================
void SPORT_PCGinit(void) {
     *pPCG_CTLA1 = 0;
     *pPCG_CTLA0 = 0;
          *pPCG_CTLA1 = CLKASOURCE | FSASOURCE;
          *pPCG_CTLA0 = BIT_8 | ENCLKA | ENFSA;
void SPORT_initSPORT1() {
          // Configure SPORT1 as Master output
          *pSPCTL1 = OPMODE | SPTRAN | SLEN24 | SPEN_A | SCHEN_A | SDEN_A;
