BF592 EZ Kite Lite SSM2603 max SAMPLE RATE 96000
Question asked by KPS on Jan 23, 2014
Latest reply on Feb 1, 2014 by Prashant
im working with the BF592 EZ KIT LITE.
I just made a few tests with the audio test programm.
I tried to realize a signal generator which uses both outputs and the left and the right channel.
It worked that far but i also wanted to realize the that with the max Samplerate.
And thats where my Problem starts.
I used folowing values to initialize the codec
unsigned char ResetControl[] =    {0x1e, 0x000}
unsigned char LeftLineIn[] = {0x00, 0x000}
unsigned char RightLineIn[] = {0x02, 0x000}
unsigned char LeftHpOut[] = {0x04, 0x07F}
unsigned char RightHpOut[] = {0x06, 0x07F}
unsigned char AnalogControl[] = {0x08, 0x015}
unsigned char DigitalControl[] = {0x0a, 0x000}
unsigned char PowerDownControl[] = {0x0c, 0x000}
unsigned char DigitalAudioFormat[] = {0x0e, 0x042}
unsigned char SamplingControl[] = {0x10, 0x01D} //96kHz USBmode
unsigned char ActiveControl[] = {0x12, 0x001}
The DMA:
*pDMA2_CONFIG = WDSIZE_32 |FLOW_1; /* 32-bit transfers, autobuffer mode*/
*pDMA2_START_ADDR = g_sInput_DMA; /* start address of data buffer */
*pDMA2_X_COUNT = 2;
*pDMA2_X_MODIFY = 4;    /* DMA loop address increment */
Sport0
*pSPORT0_RCR1 = RFSR | RCKFE;
*pSPORT0_RCR2 = SLEN_32 | RSFSE;
*pSPORT0_TCR1 = TFSR | TCKFE;
*pSPORT0_TCR2 = SLEN_32 | TSFSE;
EX_INTERRUPT_HANDLER(Sport0_RX_ISR)
/* confirm interrupt handling */
*pDMA1_IRQ_STATUS = 0x0001;
*pDMA2_IRQ_STATUS = 0x0001;
/*transmit*/
Tri=(int)((-1)*AMPLITUDE+n_Tri*(((float)AMPLITUDE)/97.0));
n_Tri++;
if(n_Tri>97){n_Tri=0;}
g_sInput_DMA[i] = Tri << 16;
i++;
g_sInput_DMA[i] = Vier << 16;
You see that i just tried to generate a sawtooth signal.
But i dont get a sample rate of 96000Hz.
It only seems to be 48000Hz.
Any idea where my mistake could be ore how i could achive my goal?
(my programm is based on the BF592_EZ_POST)
I hope someone can help.
urs sincerelly
KPS
