ADF4360-9 Max Temperature
Question asked by KJB on Jan 22, 2014
Latest reply on Feb 13, 2014 by icollins
First question:
We are running the ADF4360-9 beyond the published temperature specs.  The circuit has been run up to 125 degrees C and appears to work fine for our application.  Do you have any information as to the long term effects of operating the ADF4360-9 at this temperature for extended times?  Is there a danger of damaging the device when cycling the temperature 25 - 125 degrees C.
Second question:
The power that supplies the ADF4360-9 has a very slow ramp up time to 3.3 volts.  Is there a startup problem for the chip?  Will all of the internal circuitry operate properly with a slow moving power supply?  How soon can information be sent to the device after the power supply reaches 3.3volts?
Thanks
Ken
