Issue with heap_debug libraries and C++ (HeapFunctionMismatch)
Question asked by Rudstone on Jan 21, 2014
Latest reply on Jan 22, 2014 by AndyK2
I'd like to use the debug_heap libraries ( they have proved very handy debugging a port of an RTOS ) but there appears to be a big problem when using C++'s new and delete operators.
This can be easy reproduced as follows.
Create a new project (CCES project in C++)
set the option to "link against heap debugging libraries"
make the main application as follows
#include "stdio.h"
#include "heap_debug.h"
int main(void)
    adi_initComponents();
//    adi_core_1_enable();
    adi_heap_debug_disable( _HEAP_HPL_GEN );
    adi_heap_debug_enable( _HEAP_STDERR_DIAG );
    char *test;
    printf( "malloc'ing 16 bytes\n" );
    test = (char *)malloc( 16 );
    printf( "free'ing 16 bytes\n" );
    free( test );
    printf( "new'ing 16 bytes\n" );
    test = new char[16];
    printf( "delete'ing 16 bytes\n" );
    delete test;
    while(1)
        printf( "didn't get here\n" );
    return 0;
when running this application the console output should be as follows:
malloc'ing 16 bytes
free'ing 16 bytes
new'ing 16 bytes
delete'ing 16 bytes
Heap error in block 0xFF9039A4: allocation type mismatch
  Call stack: 0xFFA01CEC 0xFFA00128
A fatal error or exception has occurred.
  Description:   A heap operation which is incompatible with a previous operation has been detected.
  General Type:  LibraryError
  Specific Type: HeapFunctionMismatch
  General Code:  0x7
  Specific Code: 0x108
  Error Value:   0xff9039a4
  Error PC:      0xffa0226a
I have debugged this as far as I can but there is no source for the heap_debug libraries. The fault is raised in the function ___adi_heap_debug_free.
The heap debugs alloc_info block only differs in one location when using malloc and new ( 1 for malloc and 8 for new ).
would it be possible to get the source for the heap debug libraries, or a fix for this issue, or any useful information.
using:
CCES version 1.0.3.0 running on Windows 7 64 bit.
BF609 running on Avnet Finboard.
Emulating with ICE 100-B
Thanks in advance.
