Adv7611 audio setup
Question asked by Chandravelp on Jan 20, 2014
Latest reply on Jan 21, 2014 by DaveD
We are using the below configuration for adv7611 video & audio. We are sending the PCM audio to the adv7611 chip but not getting any audio from the adv7611 chip.
We have probed the MCLK LRCLK & SCLK and it's look fine (Please refer the attachment)
Checked the register status & getting the below status.
AUDIO_SAMPLE_PCKT_DET = 0
AUDIO_MODE_CHNG_RAW  = 1
Could you please give any suggestion on this?.
if we are setting the MUX_SPDIF_TO_I2S_ENABLE as 1 means we are getting some noise on the audio DAC.
0x98       0xF4  0x80           CEC
0x98       0xF5      0x7C      INFOFRAME
0x98       0xF8  0x4C      DPLL
0x98       0xF9  0x64      KSV
0x98       0xFA  0x6C      EDID
0x98       0xFB  0x68     HDMI
0x98       0xFD  0x44      CP
0x98       0x01  0x06      Prim_Mode =110b HDMI-GR
0x98       0x02  0xF5       Auto CSC, YCrCb out, Set op_656 bit
0x98       0x03  0x40     24 bit SDR 444 Mode 0
0x98       0x05  0x28     AV Codes Off
0x98       0x0B  0x44     Power up part
0x98       0x0C  0x42     Power up part
0x98       0x14  0x7F     Max Drive Strength
0x98       0x15  0x80      Disable Tristate of Pins
0x98       0x19  0x83     LLC DLL phase
0x98       0x33 0x40     LLC DLL enable
0x98       0x06  0xA6     Invert VS,HS pins
0x44       0xBA  0x01    Set HDMI FreeRun
0x64       0x40  0x81         Disable HDCP 1.1 features
0x68       0x9B  0x03     ADI recommended setting
0x68       0xC1  0x01         ADI recommended setting
0x68       0xC2  0x01         ADI recommended setting
0x68       0xC3  0x01         ADI recommended setting
0x68       0xC4  0x01         ADI recommended setting
0x68       0xC5  0x01         ADI recommended setting
0x68       0xC6  0x01         ADI recommended setting
0x68       0xC7  0x01         ADI recommended setting
0x68       0xC8  0x01         ADI recommended setting
0x68       0xC9  0x01         ADI recommended setting
0x68       0xCA  0x01         ADI recommendedA setting
0x68       0xCB  0x01    ADI recommended setting
0x68       0xCC  0x01    ADI recommended setting
0x68       0x00  0x00    Set HDMI Input Port A
0x68       0x83  0xFE    Enable clock terminator for port A
0x68       0x6F  0x0C    ADI recommended setting
0x68       0x85  0x1F    ADI recommended setting
0x68       0x87  0x70    ADI recommended setting
0x68       0x8D  0x04    LFG
0x68       0x8E  0x1E    HFG
0x68       0x1A  0x8A    unmute audio
0x68       0x57  0xDA   ADI recommended setting
0x68       0x58  0x01    ADI recommended setting
0x68       0x75  0x10    DDC drive strength
Best Regards,
Chandravel P.
