Nand Flash
Question asked by santhku@gmail.com on Jan 2, 2014
Latest reply on Jan 7, 2014 by Aaronwu
Hi
I am using BF548 Ezkit blackfin processor MT29F32G08Afaca nand flash but i am getting the following error in MTD while i compile the linux kernel. MTD is getting crashed as
OOB size: 224
No oob scheme defined for oobsize 224
------------[ cut here ]------------
kernel BUG at drivers/mtd/nand/nand_base.c:3442!
Please find the kernel below log
Welcome to minicom 2.5
Press CTRL-A Z for help on special keys
  U-Boot 2013.07 (ADI-2013R1) (Dec 14 2013 - 08:02:55)
CPU:   ADSP bf548-0.0 (Detected Rev: 0.4) (parallel flash boot)
Board: ADI BF548 EZ-Kit board
       Support: http://blackfin.uclinux.org/
Clock: VCO: 525 MHz, Core: 525 MHz, System: 131.250 MHz
RAM:   64 MiB
Flash: 16 MiB
MMC:   Blackfin SDH: 0
In:    serial
Out:   serial
Err:   serial
KGDB:  [on serial] ready
Net:   smc911x: Invalid chip endian 0x00000000
No ethernet found.
Hit any key to stop autoboot:  0
bfin>
bfin>
bfin>
bfin> bootm 0x20100000
## Booting kernel from Legacy Image at 20100000 ...
   Image Name:   bf548-0.2-3.10.10-ADI-2013R1
   Created:      2013-12-14   9:26:18 UTC
   Image Type:   Blackfin Linux Kernel Image (gzip compressed)
   Data Size:    1851712 Bytes = 1.8 MiB
   Load Address: 00001000
   Entry Point:  00335df0
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... OK
Starting Kernel at = 00335df0
Linux version 3.10.10-ADI-2013R1 (root@ubuntu) (gcc version 4.3.5 (ADI-2013R1-RC1) ) #1 Sat Dec 14 14:56:10 IST 2013
register early platform devices
bootconsole [early_shadow0] enabled
bootconsole [early_BFuart2] enabled
early printk enabled on early_BFuart2
Board Memory: 16MB
Kernel Managed Memory: 16MB
Memory map:
  fixedcode = 0x00000400-0x00000490
  text      = 0x00001000-0x0022a310
  rodata    = 0x0022a310-0x002e3e68
  bss       = 0x002e4000-0x002fb8ec
  data      = 0x002fb900-0x0032c000
    stack   = 0x0032a000-0x0032c000
  init      = 0x0032c000-0x00351000
  available = 0x00351000-0x00e00000
  DMA Zone  = 0x00e00000-0x01000000
Hardware Trace active and enabled
Boot Mode: 1
Blackfin support (C) 2004-2010 Analog Devices, Inc.
Compiled for ADSP-BF548 Rev 0.2
Warning: Compiled for Rev 2, but running on Rev 4
Warning: Unsupported Chip Revision ADSP-BF548 Rev 0.4 detected
Blackfin Linux support by http://blackfin.uclinux.org/
Processor Speed: 525 MHz core clock and 131 MHz System Clock
NOMPU: setting up cplb tables
Instruction Cache Enabled for CPU0
  External memory: cacheable in instruction cache
  L2 SRAM        : uncacheable in instruction cache
Data Cache Enabled for CPU0
  External memory: cacheable (write-through) in data cache
  L2 SRAM        : uncacheable in data cache
Built 1 zonelists in Zone order, mobility grouping off.  Total pages: 3556
Kernel command line: root=/dev/mtdblock0 mem=16M noinitrd ip=dhcp rw earlyprintk=serial,uart2,115200 console=ttyBF2,115200 rootfstype=jffs2
PID hash table entries: 64 (order: -4, 256 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Sorting __ex_table...
Memory available: 10624k/16384k RAM, (148k init code, 2212k kernel code, 1032k data, 2048k dma, 320k reserved)
NR_IRQS:295
Configuring Blackfin Priority Driven Interrupts
bfin-rtc: invalid date; resetting
Console: colour dummy device 80x25
Calibrating delay loop... 1044.48 BogoMIPS (lpj=2088960)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
Blackfin Scratchpad data SRAM: 4 KB
Blackfin L1 Data A SRAM: 16 KB (16 KB free)
Blackfin L1 Data B SRAM: 16 KB (16 KB free)
Blackfin L1 Instruction SRAM: 48 KB (42 KB free)
Blackfin L2 SRAM: 128 KB (128 KB free)
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
Blackfin DMA Controller
ezkit_init(): registering device resources
bio: create slab <bio-0> at 0
SCSI subsystem initialized
bfin-spi bfin-spi.0: master is unqueued, this is deprecated
bfin-spi bfin-spi.0: Blackfin on-chip SPI Controller Driver, Version 1.0, regs@ffc00500, dma channel@4
bfin-spi bfin-spi.1: master is unqueued, this is deprecated
bfin-spi bfin-spi.1: Blackfin on-chip SPI Controller Driver, Version 1.0, regs@ffc02300, dma channel@5
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
i2c-bfin-twi i2c-bfin-twi.0: Blackfin on-chip I2C TWI Contoller, regs_base@ffc00700
i2c-bfin-twi i2c-bfin-twi.1: Blackfin on-chip I2C TWI Contoller, regs_base@ffc02200
Advanced Linux Sound Architecture Driver Initialized.
NET: Registered protocol family 2
TCP established hash table entries: 512 (order: 0, 4096 bytes)
TCP bind hash table entries: 512 (order: -1, 2048 bytes)
TCP: Hash tables configured (established 512 bind 512)
TCP: reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
debug-mmrs: setting up Blackfin MMR debugfs
msgmni has been set to 20
io scheduler noop registered (default)
bf54x-lq043: FrameBuffer initializing...
dma_alloc_init: dma_page @ 0x009e2000 - 512 pages at 0x00e00000
Console: switching to colour frame buffer device 80x24
bfin-uart: Blackfin serial driver
bfin-uart.2: ttyBF2 at MMIO 0xffc02100 (irq = 40) is a BFIN-UART
console [ttyBF2] enabled, bootconsole disabled
bfin-otp: initialized
brd: module loaded
register bfin atapi driver
pata-bf54x pata-bf54x: Fail to reset ATAPI device
pata-bf54x: probe of pata-bf54x failed with error -14
physmap platform flash device: 02000000 at 20000000
physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000089 Chip ID 0x00881e
Intel/Sharp Extended Query Table at 0x010A
Using buffer write method
Using auto-unlock on power-up/resume
cfi_cmdset_0001: Erase suspend on write enabled
Creating 5 MTD partitions on "physmap-flash.0":
0x000000000000-0x000000080000 : "bootloader(nor)"
0x000000080000-0x000000480000 : "linux kernel(nor)"
0x000000480000-0x000000fe0000 : "file system(nor)"
0x000000fe0000-0x000000ff8000 : "config(nor)"
0x000000ff8000-0x000001000000 : "u-boot env(nor)"
m25p80 spi0.76: found mr25h256, expected m25p16
m25p80 spi0.76: mr25h256 (32 Kbytes)
Creating 2 MTD partitions on "m25p80":
0x000000000000-0x000000080000 : "bootloader(spi)"
mtd: partition "bootloader(spi)" extends beyond the end of device "m25p80" -- size truncated to 0x8000
0x000000008000-0x000000008000 : "linux kernel(spi)"
mtd: partition "linux kernel(spi)" is out of reach -- disabled
bf5xx-nand bf5xx-nand.0: data_width=8, wr_dly=3, rd_dly=3
ONFI param page 0 valid
ONFI flash detected
NAND device: Manufacturer ID: 0x2c, Chip ID: 0x48 (Micron MT29F32G08AFACAWP), 2048MiB, page size: 4096, OOB size: 224
Kernel panic - not syncing: BUG()
Hardware Trace:
   0 Target : <0x00003e0c> { _trap_c + 0x0 }
     Source : <0xffa00630> { _exception_to_level5 + 0xa4 } CALL pcrel
   1 Target : <0xffa0058c> { _exception_to_level5 + 0x0 }
     Source : <0xffa00444> { _bfin_return_from_exception + 0x18 } RTX
   2 Target : <0xffa0042c> { _bfin_return_from_exception + 0x0 }
     Source : <0xffa004e6> { _ex_trap_c + 0x72 } JUMP.S
   3 Target : <0xffa00474> { _ex_trap_c + 0x0 }
     Source : <0xffa006f6> { _trap + 0x5a } JUMP (P4)
   4 Target : <0xffa0069c> { _trap + 0x0 }
      FAULT : <0x0014ef40> { _nand_scan_tail + 0x538 } BUG
     Source : <0x0022875a> { _printk + 0x26 } RTS
   5 Target : <0x00228756> { _printk + 0x22 }
     Source : <0x0000c714> { _vprintk_emit + 0x12c } RTS
   6 Target : <0x0000c70a> { _vprintk_emit + 0x122 }
     Source : <0xffa00b20> { __common_int_entry + 0xcc } RTI
   7 Target : <0xffa00abe> { __common_int_entry + 0x6a }
     Source : <0xffa00904> { _return_from_int + 0x58 } RTS
   8 Target : <0xffa00904> { _return_from_int + 0x58 }
     Source : <0xffa008da> { _return_from_int + 0x2e } IF !CC JUMP pcrel
   9 Target : <0xffa008ac> { _return_from_int + 0x0 }
     Source : <0xffa00aba> { __common_int_entry + 0x66 } JUMP.L
  10 Target : <0xffa00ab8> { __common_int_entry + 0x64 }
     Source : <0xffa002a8> { _asm_do_IRQ + 0x60 } RTS
  11 Target : <0xffa002a0> { _asm_do_IRQ + 0x58 }
     Source : <0x0003c804> { _rcu_irq_exit + 0x4c } RTS
  12 Target : <0x0003c7fe> { _rcu_irq_exit + 0x46 }
     Source : <0x0003c7f0> { _rcu_irq_exit + 0x38 } IF CC JUMP pcrel (BP)
  13 Target : <0x0003c7ea> { _rcu_irq_exit + 0x32 }
     Source : <0x0003c75e> { _rcu_idle_enter_common + 0x56 } RTS
  14 Target : <0x0003c74c> { _rcu_idle_enter_common + 0x44 }
     Source : <0x0003c714> { _rcu_idle_enter_common + 0xc } IF !CC JUMP pcrel
  15 Target : <0x0003c708> { _rcu_idle_enter_common + 0x0 }
     Source : <0x0003c7e6> { _rcu_irq_exit + 0x2e } CALL pcrel
CPU: 0 PID: 1 Comm: swapper Not tainted 3.10.10-ADI-2013R1 #1
Stack info:
SP: [0x00827ba8] <0x00827ba8> /* kernel dynamic memory (maybe user-space) */
Memory from 0x00827ba0 to 00828000
00827ba0: 00827ba8  00000000 [00000000] 002285a2  00827ca0  00286294  002e9568  002e9568
00827bc0: 002e9568  00827bf0  002e4010  0000427c  00827ca0  ffe02014  002f5730  0000ffc0
00827be0: 00000021  00000021  00000013  00000000  0000003f  0000007b  0000001f  00000004
00827c00: 000ddd4e  00827c4c  ffa002a0  00000006  00827c38  00000006  002e9dc4  ffa00ab8
00827c20: 002e9da2  00000025  00000006  00000000  000df916  00000000  0000c70a  00008050
00827c40: 00000026  cc4663bd  00827c4c  0014c4f4  0000c70a  0000c7da  00000006  02003004
00827c60: 000ddc26  000df918  000ddc1c  000df916  00000000  00000000  00000002  ffa00634
00827c80: 002e7000 <00008008> 00000021  00304674  00000000  00000038  00000000  00000480
00827ca0: 00000480 <00008008> 00000021  cc4663bd  00827d7c  00000480  0014ef40  0014ef40
00827cc0: 00000025  02003004  000ddc26  000df918  000ddc1c  000df916  00000000  00000000
00827ce0: 00000002  00000000  00000002  00000000  00000000  0024386c  0000001f  00000038
00827d00: 00000000  00000000  00000000  00000000  00000fff  00000000  00000007  ffffffff
00827d20: 00000078  002ea234  002ec3d8  00305dd0  00000000  002e4010  008bb1c4  008bb00c
00827d40: 002f5730  00302ea0  00305db0  00002144  00000000  008bb00c  00304674  00000000
00827d60: 00000000  00000079  0000ffff  00000025  00000025  00002144  00000006  008bb000
00827d80: 000000e0  008cc000  00154064  008bb1c4  008bb000  00304674  00000001  00000008
00827da0: 00000003  00000003 <001154f2> 00304674  0031d2d8  00000000  00827e10  0031d2d8
00827dc0: 00000000  0028fdfc  00000000  002e4010  00228ee8  001156a4  00304674  0031d2d8
00827de0: 0031d2d8  003046a8  00000000  002a0160  002e4010 <001142f6> 0011563c  00317bfc
00827e00: 00000000  00000000  000da1ca  00a19660  0082360c  00862810  00115386  00a19660
00827e20: 00000007  00000067  0032c258  00114856  00827e50  001148ca  0011563c  001148dc
00827e40: 00855900  00000000  00115ae2  0028fdfc  0028aa14  00115bb4  0034e288  0033f2a0
00827e60: 0031d2d8  00000007  00000067  0014557a  00000000  002aa29c <000010f2> 0034e288
00827e80: 0033f2a0  00345218  00000007  00000067  00000000  00000006  00000006  002e4010
00827ea0: 0032c1c0  0032c1d8  0034e288  00345238  00000007  00000067  0032c258  002e4000
00827ec0: 002b1fdc  55555555  002e37e4  00000067  00000006  00000006  0032c258  0082dec8
00827ee0: 00227872  002f0a18  00824c14  00000000  00824ac0  00824d60  00311304  00307aa8
00827f00: ffa00006  002f0a18  00824ac0 <ffa00014> 002f0a18  00824c14  55555555  00227868
00827f20: 00000000  00000000  00008000  00000000  00000000  00000000  00000000  00000000
00827f40: 00000000  00000000  00000000  00000000  00000000  00000000  00000000  00000000
00827f60: 00000000  00000000  00000000  00000000  00000000  00000000  00000000  00000000
00827f80: 00000000  00000000  00000000  00000000  00000000  00000000  00000000  00000000
00827fa0: 00000000  00000000  00000000  00000000  00000000  00000000  00000000  00000000
00827fc0: 00000000  00000000  00000000  00000000  00000000  00000000  00000000  00000000
00827fe0: 00000000  00000000  00000000  00000000  00000000  00000000  ffffffff  00000006
Return addresses in stack:
    address : <0x00008008> { _isram_memcpy + 0x20 }
    address : <0x001154f2> { _driver_probe_device + 0x7a }
    address : <0x001142f6> { _bus_for_each_dev + 0x5a }
    address : <0x000010f2> { _do_one_initcall + 0xf2 }
    address : <0xffa00014> { _ret_from_fork + 0x14 }
