set  ADV7611 about WXGA4
Question asked by chongzi on Dec 28, 2013
Latest reply on Dec 30, 2013 by raymondcarter
       I want adv7611 work with WXGA4(1366X768@60HZ).I set registers as:
         IO part:
            {0x01, 0x06},  // Prim_Mode =110b HDMI-GR
            {0x02, 0xF5},  // Auto CSC, YCrCb out, Set op_656 bit
            {0x03, 0x80},  // 24 bit SDR 444 Mode 0
            {0x05, 0x24},  // AV Codes Off 0x28 0x24
            {0x06, 0xA6},  // Invert VS,HS pins
            {0x0B, 0x44},  // Power up part
            {0x0C, 0x42},  // Power up part
            {0x14, 0x7F},  // Max Drive Strength
            {0x15, 0x80},  // Disable Tristate of Pins
            {0x19, 0x80},  // LLC DLL phase
            {0x33, 0x40},  // LLC DLL enable
       CP part:
           {0x7b, 0x04},//AV_POS_SEL
           {0x8F, 0x02},//CH1_FR_LL
           {0x90, 0x56},//CH1_FR_LL
           {0x91, 0x00},//INTERLACED
           {0xAB, 0x31}, //CP_LCOUNT_MAX
           {0xAC, 0xE0},//CP_LCOUNT_MAX
           {0xBA, 0x01},//HDMI_RUN_EN
           {0xC9, 0x01},//DIS_AUTO_PARAM_BUFF
        HDMI part:
          {0x9B, 0x03},  //ADI recommended setting
          {0xC1, 0x01},  //ADI recommended setting
          {0xC2, 0x01},  //ADI recommended setting
          {0xC3, 0x01},  //ADI recommended setting
          {0xC4, 0x01},  //ADI recommended setting
          {0xC5, 0x01},  //ADI recommended setting
          {0xC6, 0x01},  //ADI recommended setting
          {0xC7, 0x01},  //ADI recommended setting
          {0xC8, 0x01},  //ADI recommended setting
          {0xC9, 0x01},  //ADI recommended setting
          {0xCA, 0x01},  //ADI recommended setting
          {0xCB, 0x01},  //ADI recommended setting
          {0xCC, 0x01},  //ADI recommended setting
          {0x00, 0x00},  //Set HDMI Input Port A
          {0x83, 0xFE},  //Enable clock terminator for port A
          //{0x6C, 0x02},
          {0x6F, 0x0C},  //ADI recommended setting
          {0x85, 0x1F},  //ADI recommended setting
          {0x87, 0x70},  //ADI recommended setting
          {0x8D, 0x04},  //LFG
          {0x8E, 0x1E},  //HFG
          {0x1A, 0x8A},  //unmute audio
          {0x57, 0xDA},  //ADI recommended setting
         {0x58, 0x01},  //ADI recommended setting
         {0x75, 0x10},  //DDC drive strength
        Measure Hs ,Vs and LLC.Hs is 47.7KHZ. Vs is 60HZ. Colock is 38.3MHZ. Colock is incorrect,should be 85.75MHZ.
         How to solve the question? Help me, please.
