how to burn program into spi flash in right way
Question asked by samuel_zhang@jabil.com on Dec 20, 2013
Latest reply on Jan 29, 2014 by davidf@phasetronics.com
Dear all:
About the former issue - DSP is not running in right way after burning image into SPI flash, I take some experiments to diagnose.
Finally, I found out that the process of burning is no problem - I have written a spi flash reading program so that I can compare data captured from SPI flash with the binary file (ADSP21469_PBLED.ldr - building in binary format, not Hex).
Of course, it's done after burning the file into spi flash and reset. In the end, I find no difference  between captured data and binary file.
So the only root cause can only locate in procedure after reset:
1) Bootrom read BOOT_CFGx - should be spi master mode
2) Load image from SPI flash into memory (base address: 0x8c005, right?)
3) Execute kernel part of image starting from base address
4) In the end of kernel part, it will copy 2nd part of image - application part to base address(0x8c005) and run it.
But unfortunately, I can't make program stays in "main" function entry through breakpoint setting which proves that the program has run away.
Afterwards, I use another way to observe what happens: reset mcu after burning and trace PC flow.
1) Reset DSP after burning
2) And now PC (register) will halt in address (0x8c005).
Inline image 1
3) Load symbol file (ADSP21469_PBLED.ldr.dxe) to help debug
Inline image 2
4) type "f11" to step in, and PC will jump to "___lib_start".
Inline image 3
5) Now you can see the instruction address "0x126041" is invalid which can't be found in symbol file. If you keep on running (F11), PC will run away - to somewhere I don't know.
Inline image 4
6) Meanwhile, If you watch address of main function - it should be 0x124504 which is got form project map file (ADSP21469_PBLED.ldr.map.xml), you will also find the instruction block is fully wrong.
Inline image 5
Inline image 6
And you can also prove this since you can't find binary bytes "000059BE" in binary file (ADSP21469_PBLED.ldr).
Above is the experiment result in snapshot, I will also attach pictures and projects for your reference.
In the other hand, right instructions for both "main" function and "___lib_start" can be easily retrieved if you download "ADSP21469_PBLED.dxe" through JTAG emulator.
1) Main function instruction block
Inline image 7
You can also find that breakpoint woks in place.
Inline image 10
In addition, you can find instruction "0x00001804" of main function in "ADSP21469_PBLED.ldr".
2) "___lib_start" instruction block
Inline image 9
Inline image 8
After all, I suspect the process of building "ADSP21469_PBLED.ldr" is somewhere wrong or the kernel  file "C:\Program Files\Analog Devices\VisualDSP 5.0\214xx\ldr\469_spi.dxe" is not the right one.
But I can't debug on this file since I don't understand how kernel file should be linked as header of final loader file "ADSP21469_PBLED.ldr". This may need ADI engineer's help.
Below is description of loader file building process and burning process.
1) Building process:
I choose these options in "Project:Load:General" page:
A. Boot Type - SPI master
B. Format: Binary
C. Width: 8-bit
D. User default kernel - direct to "C:\Program Files\Analog Devices\VisualDSP 5.0\214xx\ldr\469_spi.dxe"
Inline image 11
2) Burning process:
1) Driver: "21469EzFlashDriver_Serial.dxe" which is generated from 21469 start-kit example project under folder "C:\Program Files\Analog Devices\VisualDSP 5.0\214xx\Examples\ADSP-21469 EZ-Board\Flash Programmer\Serial".
We use same flash with EZ-Board - m25p16.
2) Programming:
A. Erase all
B. Binary (start from 0x0)
C. Data - ADSP21469_PBLED.ldr
D. Verify while programming
Inline image 12
So that'all, please help to find out what's the matter.
By the way, the flash programmer I used to read spi flash is also attached.
Thanks very much!
