When are DMA callbacks called?
Question asked by gpetrowitsch on Jun 22, 2010
Latest reply on Jun 24, 2010 by gpetrowitsch
Hi all,
I'm using a SPORT in conjunction with DMA to output audio data.
To enable me mixing new incoming audio streams with a currently
playing stream, I chop the streams into small portions of 25ms duration.
Unfortunately, when I do this, I can hear a 40Hz hum, which is due to
the small periods of time it takes me to write another buffer to the DMA.
Now I tried to first chain two 25ms-chunks to the DMA and each time, the first of
the two is completed by the DMA write another one until all have been processed.
Unfortunately, it seems, that I don't get a callback for each chunk, but only
if the last one has been processed.
How can I make the DMA call the callback each time one of the chained
sub-buffers has been processed?
I'm using mode ADI_DEV_MODE_CHAINED and buffer type ADI_DEV_1D.
I chain the small 25ms-chunks with adi_dev_Write calls.
Thanks & kind regards,
Gerhard
