adv7619 1920 x 1080p 120hz support?
Question asked by bkkim on Dec 18, 2013
Latest reply on Jan 7, 2016 by GuenterL
Hi
I use ADV7619.
I need to be tested 1920 x 1080p 120hz.
1920 x 1080p 60hz is operates well.
But 1920 x 1080p 120hz is Not operates.
- 1920 x 1080p 120hz
     LLC: Signal is output
     DE : Signal is not output
     HS : Signal is not output
     VS : Signal is not output
- I2C Setting Value
98 FF 80 ; I2C reset
98 F4 80 ; CEC
98 F5 7C ; INFOFRAME
98 F8 4C ; DPLL
98 F9 64 ; KSV
98 FA 6C ; EDID
98 FB 68 ; HDMI
98 FD 44 ; CP
68 C0 03 ; ADI Recommended Write
98 01 06 ; Prim_Mode =110b HDMI-GR
98 02 F2 ; Auto CSC, RGB out, Set op_656 bit
98 03 54 ; 2x24 bit SDR 444 interleaved mode 0
98 05 28 ; AV Codes Off
98 06 A0 ; No inversion on VS,HS pins
98 0C 42 ; Power up part
98 15 80 ; Disable Tristate of Pins
98 19 83 ; LLC DLL phase
98 33 40 ; LLC DLL MUX enable
4C B5 01 ; Setting MCLK to 256Fs
68 C0 03 ; ADI Required write
68 00 08 ; Set HDMI Input Port A (BG_MEAS_PORT_SEL = 001b)
68 02 03 ; ALL BG Ports enabled
68 03 98 ; ADI Required Write
68 10 A5 ; ADI Required Write
68 45 04 ; ADI Required Write
68 97 C0 ; ADI Required Write
68 3D 10 ; ADI Required Write
68 3E 69 ; ADI reccommended writes
68 3F 46 ; ADI reccommended writes
68 4E FE ; ADI reccommended writes
68 4F 08 ; ADI reccommended writes
68 50 00 ; ADI Recommended Write
68 57 A3 ; ADI reccommended writes
68 58 07 ; ADI reccommended writes
68 83 FC ; Enable clock terminators for port A & B
68 84 03 ; FP MODE
68 85 10 ; ADI recommended setting
68 86 9B ; ADI recommended setting
68 89 03 ; HF Gain
68 9B 03 ; ADI recommended setting
68 93 03 ; ADI recommended setting
68 5A 80 ; ADI recommended setting
