Blackfin SPI DMA-driven with SC16IS750
Question asked by mrgabu on Dec 16, 2013
Latest reply on Feb 1, 2014 by Prashant
Hello guys,
I'm working on a VDK driver for BF518 to communicate with SC16IS750 using SPI.
Hardware : ADSP-BF518F ezboard and SC16IS750 custom board.
First of all I'm using interrupt mode to configure the bridge IC (SPI to UART) and then I must send a lot of data using FIFO mode write cycle.
Using interrupt to send data is inconvenient, because the TX LVL exceeds 64 bytes (chip limit) very quickly and I have to wait RX answer and then send more data. On my application I can't wait.
My idea is use SPI in DMA mode (UART will work at almost 1Mbps and SPI at 5Mbps).
As I found on docs (adi_spi_dma.pdf , 8.1.2. Outbound Example), I must start the Driver with ADI_DEV_PDD_ENTRY_POINT but without a ADI_DMA_MANAGER_HANDLE.
BTW, I tried without DMA Handler and With DMA Handler.
All of commands returned SUCCESS (for DEV and DMA return codes) but I can't trace any signal on MISO lines using a osciloscope...
Using interrupt everything works as expected.
Someone used SPI in DMA mode or can send some considerations to use it with NXP SC16IS750 FIFO write cycle ?
Thanks in advanced
Best regards.
