Adis16209 Problems Getting Data From It
Question asked by Messias on Dec 11, 2013
Latest reply on Jan 29, 2014 by NevadaMark
Hello!
I am during some days trying to put working the ADIS16209. However, I'm not getting it.
I started to try read the temperature register, but until now without success.
#include <SPI.h>
// ADIS16209 register addresses
const int X_ACCL = 0x04;
const int Y_ACCL = 0x06;
const int X_INCL = 0x0C;
const int Y_INCL = 0x0E;
const int ROT = 0x10;
const int TEMP = 0x0A;
const int SMPL_PRD = 0x36;  // Sample Rate
const int AVG_CNT = 0x38;   // Filter Configuration
void setup() {
  // initialize the serial communications:
  Serial.begin(57600);
  //////SPI SETUP/////////////
  SPI.begin();
  SPI.setClockDivider(SPI_CLOCK_DIV16);  // SPI 1MHz <--AS ON DATASHEET
  SPI.setDataMode(SPI_MODE3);  // CPOL=1 && CPHA=1 <-- AS ON DATASHEET
  // declare SS as output
  pinMode(SS, OUTPUT);
  digitalWrite(SS, HIGH);
  pinMode(49, OUTPUT);
  digitalWrite(49, HIGH);
  // PRINT TO SERIAL PORT
  Serial.print("X_ACCL (mg)");
  Serial.print("\t");
  Serial.print("Y_ACCL (mg)");
  Serial.print("\t");
  Serial.print("X_INCL (grau)");
  Serial.print("\t");
  Serial.print("Y_INCL (grau)");
  Serial.print("\t");
  Serial.print("ROT (grau)");
  Serial.print("\t");
  Serial.print("TEMP (C)");
  Serial.println();
void loop() {
  Serial.println("TEMPERATURA: ");
  Serial.print( readTemp(), DEC); //////////TRYING READ TEMPERATURE
  Serial.println();
  readALLSensor();
  delay(1000);
void readALLSensor() {
//  Serial.print( readRegister(X_ACCL), DEC);
//  Serial.print("\t");
//  Serial.print( readRegister(Y_ACCL), DEC);
//  Serial.print( readRegister(X_INCL), DEC);
//  Serial.print( readRegister(Y_INCL), DEC);
//  Serial.print( readRegister(ROT), DEC);
  Serial.print( readRegister(TEMP), DEC);
  Serial.println();
/***************************SEE THIS FUNCTION, I DID IT TO TEST THE READ OF A REGISTER*************/
float readTemp() {
  unsigned int result = 0;
  unsigned int lower = 0;
  unsigned int upper = 0;
  float result_converted = 0;
  digitalWrite(SS, LOW);
  delayMicroseconds(1); // Datasheet says 50 ns at least
  SPI.transfer(0x0A);  // Read the lower temperature bits
  lower = SPI.transfer(0x00);
  delayMicroseconds(10);
  SPI.transfer(0x0B);
  upper = SPI.transfer(0x00);
  upper = upper << 8;
  result = upper | lower;
  delayMicroseconds(50);
    result_converted = (result & (0b0000111111111111));
    result_converted = (result_converted - 1278)*(-0.47) + 25;
return (result_converted);
float readRegister(byte thisRegister) {
  SPI.transfer(thisRegister);  // To put the 8th bit at 0/1 read/write: thisRegister &= ~(1u << 7)
  upper = upper << 8;
  //CONVERSION
  if (thisRegister == TEMP) {   // Temperature
  else if ((result >> 13) & 1) {  // Inclinometer & Accelerometer
    result = result & (0b0011111111111111);
    result = ~result + 1;
    result_converted =(float)result*(-1);
    result_converted *= 0.025;
  else {  // Inclinometer & Accelerometer
    result_converted = (float)result;
return result_converted;
I appreciate your attention and help. I already try a lot of things but without success.
Thank you,
Andre.
