Please help, every time I read zero value
Question asked by sami3 on Dec 6, 2013
Latest reply on Dec 15, 2013 by sami3
I am student, currently we are using ADE7880 IC together with Raspberry pi for energy and RMS value measurement. However am facing a problem which I couldn't solve nor understand.
Am trying to read the values form AWATTHR, AFWATTHR, APF, AVRMS & AIRMS. but am reading zero value all the time.
                  For the test, I have connected the CT output to IAP & IAN terminal just as shown in (Figure 3. Example of a Current Transformer Connection) from this document http://www.analog.com/static/imported-files/user_guides/UG-356.pdf
The neutral input and all other ground are connected to the Rpi ground. And as I varied the current, i checked the IAP & IAN Pin via oscilloscope the result is ok (but the signal is noisy ,I don’t know if this creates a problem).
The SPI connection is working properly and whenever I write to the configuration registers I rechecked the values in LAST_OP,LAST_ADD and LAST_RWDATA registers and no error. My configuration procedure is taken from the datasheet ADE7880 QUICK SETUP AS ENERGY METER section page 80, but I skip point 2,3 and 4.
Similarly the voltage input is connected according to the above user guide, but the situation is the same.
Please help me on this problem.
