BF609 PIXC DMA LIST 读取错误。
Question asked by qian on Nov 29, 2013
Latest reply on Nov 29, 2013 by qian
我的链表配置方式如下:
/* DMA descriptor work unit for PDMA */
typedef struct
    volatile void       *pNextDesc;         /* Pointer to next Descriptor */
    volatile void       *pStartAddr;        /* Start address of current buffer */
    volatile uint32_t   Config;             /* Configuration register */
    volatile uint32_t   XCount;             /* XCOUNT - Inner loop count start value in number of MSIZE data transfers*/
    volatile int32_t    XModify;            /* XMODIFY - Inner loop address increment, in bytes */
    volatile uint32_t   YCount;             /* YCOUNT - Outer loop count start value (2D only), in number of rows*/
    volatile int32_t    YModify;            /* YMODIFY - Outer loop address increment (2D only), in bytes*/
} PDMA_DESC_WORK_UNIT;
#pragma section("L1_data")
#pragma align 32
PDMA_DESC_WORK_UNIT OSD_DMA35_DescriptorCopy[6];
void dma35List(void)
OSD_DMA35_DescriptorCopy[0].pNextDesc                     = &OSD_DMA35_DescriptorCopy[1];// 下一个描述符地址
          //OSD_DMA15_DescriptorCopy[0].Config                              = DMAEN | WDSIZE_32 | DMA2D | NDSIZE_9 | FLOW_LARGE;// DMA config
          OSD_DMA35_DescriptorCopy[0].Config                              = ENUM_DMA_CFG_READ    |
        ENUM_DMA_CFG_EN             |
        ENUM_DMA_CFG_MSIZE04 |
        ENUM_DMA_CFG_PSIZE04 |
        ENUM_DMA_CFG_ADDR2D  |
        ENUM_DMA_CFG_FETCH07 |
        ENUM_DMA_CFG_DSCLIST;
          OSD_DMA35_DescriptorCopy[0].XCount                              = 640*2/4;                              // X Count
          OSD_DMA35_DescriptorCopy[0].XModify                              = 4;                                        // X Mod
          OSD_DMA35_DescriptorCopy[0].YCount                              = (512-32)/2;                    // Y Count
          OSD_DMA35_DescriptorCopy[0].YModify                              = (720-640)*2+4;
          OSD_DMA35_DescriptorCopy[1].pNextDesc                     = &OSD_DMA35_DescriptorCopy[2];// 下一个描述符地址
          //OSD_DMA15_DescriptorCopy[1].Config                    = DMAEN | WDSIZE_32 | DMA2D | NDSIZE_9 | FLOW_LARGE;// DMA config
          OSD_DMA35_DescriptorCopy[1].Config                              = ENUM_DMA_CFG_READ    |
        ENUM_DMA_CFG_EN             |
          OSD_DMA35_DescriptorCopy[1].XCount                              = ((640-32)/2)*2/4;          // X Count
          OSD_DMA35_DescriptorCopy[1].XModify                              = 4;                                        // X Mod
          OSD_DMA35_DescriptorCopy[1].YCount                              = 32;                                        // Y Count
          OSD_DMA35_DescriptorCopy[1].YModify                              = (720-((640-32)/2))*2+4;
          OSD_DMA35_DescriptorCopy[2].pNextDesc                     = &OSD_DMA35_DescriptorCopy[3];// 下一个描述符地址
          //OSD_DMA15_DescriptorCopy[2].Config                    = DMAEN | WDSIZE_32 | DMA2D | NDSIZE_9 | FLOW_LARGE;// DMA config
          OSD_DMA35_DescriptorCopy[2].Config                              = ENUM_DMA_CFG_READ    |
        ENUM_DMA_CFG_EN             |
          OSD_DMA35_DescriptorCopy[2].XCount                              = ((640-32)/2)*2/4;          // X Count
          OSD_DMA35_DescriptorCopy[2].XModify                              = 4;                                        // X Mod
          OSD_DMA35_DescriptorCopy[2].YCount                              = 32;                                        // Y Count
          OSD_DMA35_DescriptorCopy[2].YModify                              = (720-((640-32)/2))*2+4;
          OSD_DMA35_DescriptorCopy[3].pNextDesc                     = &OSD_DMA35_DescriptorCopy[4];// 下一个描述符地址
//          OSD_DMA15_DescriptorCopy[3].Config                              = DMAEN | WDSIZE_32 | DMA2D | NDSIZE_9 | FLOW_LARGE;// DMA config
          OSD_DMA35_DescriptorCopy[3].Config                              = ENUM_DMA_CFG_READ    |
        ENUM_DMA_CFG_EN             |
          OSD_DMA35_DescriptorCopy[3].XCount                              = 640*2/4;                              // X Count
          OSD_DMA35_DescriptorCopy[3].XModify                              = 4;                                        // X Mod
          OSD_DMA35_DescriptorCopy[3].YCount                              = (512-32)/2-128;          // Y Count
          OSD_DMA35_DescriptorCopy[3].YModify                              = (720-640)*2+4;
          OSD_DMA35_DescriptorCopy[4].pNextDesc                     = &OSD_DMA35_DescriptorCopy[5];// 下一个描述符地址
//          OSD_DMA15_DescriptorCopy[4].Config                              = DMAEN | WDSIZE_32 | DMA2D | NDSIZE_9 | FLOW_LARGE;// DMA config
          OSD_DMA35_DescriptorCopy[4].Config                              = ENUM_DMA_CFG_READ    |
        ENUM_DMA_CFG_EN             |
          OSD_DMA35_DescriptorCopy[4].XCount                              = (640-160)*2/4;          // X Count
          OSD_DMA35_DescriptorCopy[4].XModify                              = 4;                                        // X Mod
          OSD_DMA35_DescriptorCopy[4].YCount                              = 128;                                        // Y Count
          OSD_DMA35_DescriptorCopy[4].YModify                              = (720-(640-160))*2+4;
          //与开窗重合
          OSD_DMA35_DescriptorCopy[5].pNextDesc                     = &OSD_DMA35_DescriptorCopy[5];// 下一个描述符地址
//          OSD_DMA15_DescriptorCopy[5].Config                              = DMAEN | WDSIZE_32 | DMA2D | FLOW_STOP;// DMA config  结束
          OSD_DMA35_DescriptorCopy[5].Config                              = ENUM_DMA_CFG_READ    |
        ENUM_DMA_CFG_EN             |
        ENUM_DMA_CFG_STOP;
          OSD_DMA35_DescriptorCopy[5].XCount                              = 160*2/4;                              // X Count
          OSD_DMA35_DescriptorCopy[5].XModify                              = 4;                                        // X Mod
          OSD_DMA35_DescriptorCopy[5].YCount                              = 128;                                        // Y Count
          OSD_DMA35_DescriptorCopy[5].YModify                              = (720-160)*2+4;
void pixc_cfg(void)
          *pREG_PIXC0_TRANSP_A = TranspRatio;//透明度 0~F--50%
          *pREG_PIXC0_PPL = 1276;//行内计数
          *pREG_PIXC0_LPF = 256;//逐行叠加
          *pREG_PIXC0_HSTART_A = 0;//行开始
          *pREG_PIXC0_HEND_A = 1276+1;//行结束
          *pREG_PIXC0_VSTART_A = 0;//垂直开始
          *pREG_PIXC0_VEND_A = 256;//垂直结束
          //*pPIXC_CTL =  TC_EN;//不叠加OSD 只复制
          *pREG_PIXC0_CTL =  BITM_PIXC_CTL_ENTC;//不叠加OSD 只复制
          *pREG_DMA35_DSCPTR_NXT=(&OSD_DMA35_DescriptorCopy[0]);
          *pREG_DMA37_DSCPTR_NXT=(&OSD_DMA37_DescriptorCopy[0]);
          if((*pREG_DMA37_STAT &BITM_DMA_STAT_RUN)==0)//判断输出DMA状态
                    //开启使能 必须先开启DMA
//                    *pDMA15_CONFIG = DMAEN | NDSIZE_9 | FLOW_LARGE;// DMA config
//                    *pDMA17_CONFIG = DMAEN | NDSIZE_9 | FLOW_LARGE;// DMA config
                    *pREG_DMA35_CFG  =          ENUM_DMA_CFG_READ   |
        ENUM_DMA_CFG_EN |
                    *pREG_DMA37_CFG  =          ENUM_DMA_CFG_WRITE   |
        ENUM_DMA_CFG_EN |
                    ssync();
                    //使能PIXC
                    //*pPIXC_CTL |= PIXC_EN;
                    *pREG_PIXC0_CTL |= BITM_PIXC_CTL_EN;
                    ssync();
当使能PIXC以后。
DMA35_37_STAT都有错误:0X00006002
寄存器截图为:
我无法找到DMA错误的原因。
