VisualDSP++ Codes
Question asked by neoplay on Nov 28, 2013
Latest reply on Dec 3, 2013 by neoplay
Following some samples codes and here are couple sections from it;
*  global variables and defines
#define LEFT_LINE_IN                                                  0x0000
#define RIGHT_LINE_IN                                                  0x0200
#define LEFT_HEADPHONE_OUT                                0x0400
#define RIGHT_HEADPHONE_OUT                               0x0600
#define ANALOG_AUDIO_PATH_CONTROL                     0x0800
#define DIGITAL_AUDIO_PATH_CONTROL                     0x0a00
#define POWER_DOWN_CONTROL                                         0x0c00
#define DIGITAL_AUDIO_INTERFACE_FORMAT           0x0e00
#define SAMPLING_CONTROL                                         0x1000
#define ACTIVE_CONTROL                                                   0x1200
#define RESET_CONTROL                                                   0x1E00
#define CODEC_REGS_LENGTH9
volatile short sCodecTxRegs[CODEC_REGS_LENGTH] =
          LEFT_LINE_IN                                       | 0x01b,          /* greater than 0db volume */
          RIGHT_LINE_IN                                     | 0x01b,          /* greater than 0db volume */
          LEFT_HEADPHONE_OUT                      | 0x07f,          /* gain */
          RIGHT_HEADPHONE_OUT                    | 0x07f,          /* gain */
          ANALOG_AUDIO_PATH_CONTROL        | 0x010,
          DIGITAL_AUDIO_PATH_CONTROL         | 0x000,
          POWER_DOWN_CONTROL                   | 0x000,
          DIGITAL_AUDIO_INTERFACE_FORMAT  | 0x042,
          SAMPLING_CONTROL        | 0x000,          /* set Normal mode */
I can understand that sCodecTxRegs[] is a array of 9 with elements of two bytes long. however, I am not sure how the contents of this array is written to the Codec registers since it only been used twice later in the code as follow:
if( bMicInLineOut )
                              bMicInLineOut = false;
  /* INSEL = Line Input Select to ADC */
                              sCodecTxRegs[4] &= 0xFFFB;
                    else
                              bMicInLineOut = true;
                              /* INSEL = Microphone Input Select to ADC */
                              sCodecTxRegs[4] |= 0x4;
Could someone tell me if sCodecTxRegs[] is a defined function so that the content would be written to the CODEC without any other code?
Thanks in advance
--Neo
