Why is there such a long delay in Talkthru Analog In-Out?
Question asked by bluefrog on Nov 26, 2013
Latest reply on Nov 28, 2013 by bluefrog
I started with the Talktru Analog In-Out example program using an ADZS-21369-EZLITE.  I slightly rewrote the program so I could get data in and out of my program.  When I ran the program I noticed about a 60 sample delay between the input and output.  I assume the example program has the same delay.  I finally reduced my interrupt routine to the program below.  I took a sine wave and split it into RXSP0A and a scope and then took the signal from TXSP1B into the other channel of the scope.  I find about a 1.3ms delay between the two scope waveforms.  Is there someway to configure the SPORT to reduce this?  Do I need to use DMA?  Which manual applies to the 21369, the "2136x SHARC Processor Hardware Reference" manual doesn't include the 21369?
Hal
.section /pm seg_pmco;
.global _talkThroughISR;
_talkThroughISR:
       HLoop: r14=r14 XOR r15;
    if EQ JUMP HRight;
r10=dm(RXSP0A);          // Read new left sample from ADC
          r13=LSHIFT r10 BY 0x08;
f13=FLOAT r13;
dm(TXSP1B)=r10; //to scope channel
rti;
HRight:
         r10=0;
dm(TXSP1B)=r10;
r10=dm(RXSP0A);    //dummy read
rti;
//NAME:     main.asm        //
//DATE:     7/29/05        //
//PURPOSE:  ADSP-21369 EZ-KIT Test. Calls initialization routines then waits for interrupts  //
//USAGE:    This file contains the main routine calls functions to set up the talkthrough    //
//          routine. It receives an input signal from the ADC via SPORT0A and outputs to     //
//          DAC's via SPORT1A, SPORT1B, SPORT2A, and SPORT2B.                                //
#include <def21369.h>
#include "btc.h"   //BTC channel to observe variables
.global _main;
.extern _initPLL;
.extern _initSDRAM;
.extern _initSRU;
.extern _initSPORT;
.extern _init1835viaSPI;
.extern _initMLS;
.extern _initFIR;
_main:
    call _initPLL;        // Initializes PLL for the correct core clock (CCLK) frequency
    call _initSDRAM;      // Initializes SDRAM for the correct SDRAM clock (SDCLK) frequency
    call _initSRU;        // Initializes the SRU & DAI/DPI pins
    call _init1835viaSPI; // Initializes the codec
    call _initMLS;       //  Initialize MLS sequence generator
    call _initFIR;          //  Initialize  FIR
    call _initSPORT;      // Initializes the transmit and receive serial ports (SPORTS)
    // Enable interrupts (globally)
    BIT SET MODE1 IRPTEN;
    // Unmask the SPORT0 ISR
    LIRPTL = SP0IMSK;
_main.end:
    // Loop forever.  Work is driven by interrupts
    jump (pc,0);
init1835viaSPI.asm
#include "ad1835.h"
.global _init1835viaSPI;
.section/dm seg_dmda;
.var spi_semaphore;
.var config_tx_buf[]=          // Buffer of configuration data
            WR | DACCTRL1 | DACI2S | DAC24BIT | DACFS48,
            WR | DACCTRL2, // e.g.: | DACMUTE_R1 | DACMUTE_L2,
            WR | DACVOL_L1 | DACVOL_MAX,
            WR | DACVOL_R1 | DACVOL_MAX,
            WR | DACVOL_L2 | DACVOL_MAX,
            WR | DACVOL_R2 | DACVOL_MAX,
            WR | DACVOL_L3 | DACVOL_MAX,
            WR | DACVOL_R3 | DACVOL_MAX,
            WR | DACVOL_L4 | DACVOL_MAX,
            WR | DACVOL_R4 | DACVOL_MAX,
            WR | ADCCTRL1 | ADCFS48,
            WR | ADCCTRL2 | ADCI2S | ADC24BIT,
            WR | ADCCTRL3 | IMCLKx2 | PEAKRDEN;
.section/pm seg_pmco;
_init1835viaSPI:
    // Clear SPTFLG and SPICTL regs to start
    r0 = 0;
    dm(SPICTL)=r0;
    dm(SPIFLG)=r0;
    // Writing TXFLSH and RXFLSH bits in SPICTL clear the SPI
    // transmit and receive FIFOs, respectively.
    r0 = dm(SPICTL);
    r1 = (TXFLSH | RXFLSH );
    r0 = r0 OR r1;
    dm(SPICTL)=r0;
    // Setup the baud rate to 500 KHz
    r0 = 100;
    dm(SPIBAUD) = r0;
    // Set the SPIFLG register to FLAG3 (0xF708)
    r0 = 0xF708;
    dm(SPIFLG) = r0;
    // Now set the SPI control register
    r0 = (SPIEN |   // enable the port
          SPIMS |   // set SHARC as SPI master
          MSBF |    // send MSB first
          WL16 |    // word length = 16 bits
          TIMOD1);  // Initialize SPI port to begin
                    // transmitting when DMA is enabled
    dm(SPICTL) = r0;
    // Set up DAG registers to transmit via SPI
    i4 = config_tx_buf;
    m4 = 1;
    // Set up loop to transmit data
    lcntr = LENGTH(config_tx_buf), do word_sent until lce;
        // Send a word
        r0=dm(i4,m4);
        dm(TXSPI)=r0;
        // Wait until "SPI transfer complete" status bit
        //   in SPISTAT (SPIFE) indicates that we can send more
        do checkIfTXisDone until TF;
            ustat3 = dm(SPISTAT);
            BIT TST ustat3 SPIFE;
        checkIfTXisDone:
        nop;
        // Wait an extra 100 cycles to meet the timing
        //   requirements of the AD1835A
        lcntr = 100, do pauseFor1835 until lce;
        pauseFor1835:
        nop;
    word_sent:
    nop;
    // Flush SPI buffers after initialization
    //   You may want to do this before sending
    //   other SPI commands to guarantee that
    //   you have not accidentally left data in
    //   the transmit or receive FIFOs.
    r0 = dm(SPICTL);
    r0 = r0 OR r1;
    dm(SPICTL)=r0;
_init1835viaSPI.end:
    rts;
//NAME:     initSPORT.asm
//DATE:     7/29/05
//USAGE:    This file initializes the transmit and receive serial ports (SPORTS). It uses
//               uses SPORT0 to receive data from the ADC and transmits the data to the DAC's
//               via SPORT1A, SPORT1B, SPORT2A and SPORT2B.
#include <Main.h>
.global _initSPORT;
.extern H;
.extern HCount;
.extern HiCount;
.extern HirCount;
.extern Mike;
_initSPORT:
// Make sure that the multichannel mode registers are cleared
r0 = 0;
dm(SPMCTL0) = r0;
dm(SPMCTL1) = r0;
dm(SPMCTL2) = r0;
dm(SPCTL0) = r0;
dm(SPCTL1) = r0;
dm(SPCTL2) = r0;
// Configure SPORT 0 as a receiver (input from ADC)
//    OPMODE = I2S mode
//    SLEN24 = 24 bit of data in each 32-bit word
//    SPEN_A = Enable data channel A
r0 = OPMODE | SLEN24 | SPEN_A;
dm(SPCTL0) = r0;
// Configure SPORTs 1 & 2 as transmitter (output to DACs 1-4)
//    SPTRAN = Transmit on serial port
//    SPEN_B = Enable data channel B
r0 = SPTRAN | OPMODE | SLEN24 |SPEN_B ;
dm(SPCTL1) = r0;
dm(SPCTL2) = r0;
r14=0xFFFFFFFF;
r15=0xFFFFFFFF;
r3=22;      //initialize  shift of float conversion
r5=0;       //adaptation modes
r1=HCountInit;
dm(HCount)=r1;
b0=Mike;
l0=MikeTaps;
m0=1;
b8=H;
l8=HTaps;
m8=1;
r1=HTaps;
f5=0;
r9=0;       //initial mode
rts;
_initSPORT.end:
