Audio signal (S/PDIF) on EVAL-ADV7619-7511P
Question asked by ggottawa on Nov 25, 2013
Latest reply on Dec 12, 2013 by ggottawa
Hi.
On the evaluation board (EVAL-ADV7619-7511P), I want to confirm that both S/PDIF & I2S (audio) are working.
To me, it looks like the selection of the output audio format is manipulated in ADV7511.
The following registers of ADV7511 are used for setup:
0x0A - bit "654":      Audio select
0x0B - bit "7"          SPDIF enable
0x0C - bit "5432"    I2S enable
The I2S responded correctly.
While 0x0A - bit "654" are set to "000" to select I2S:
- when 0x0C-bit "2" is 1, an MP3 audio file is played . (for MP3 format, only I2S0 is used. )
- when 0x0C-bit "2" is 0, there was no sound.
That is perfect.
By the way, SPDIF did not respond properly.
While 0x0A - bit "654" are set to "001" to select SPDIF, an MP3 audio file is always played whether 0x0B-bit 7 is 0 or 1.
In other words, an MP3 file is played even when SPDIF is disabled (0x0B-bit 7 is 0).
Does it make sense?
With this observation, I am not even sure if the output audio is actually SPDIF.
Thank you.
