TWI Interface
Question asked by neoplay on Nov 22, 2013
Latest reply on Dec 19, 2013 by VineethaThomas
I am learning the Blackfin by following some sample code. Now I am studying how TWO works and here are some codes;
function prototype:
void TWI_MasterMode_Write(unsigned short DeviceAddr, unsigned char *TWI_Data_Pointer, unsigned short Count, unsigned short TWI_Length);
variable for the function
unsigned char RightLineIn[] =                     { 0x02, 0x01b};
Function calling
TWI_MasterMode_Write( CODEC_TWI_ADDRESS, RightLineIn, 1, 2);
An the function in details
*   Function:    TWI_MasterMode_Write
*   Description: do a master mode write
          int i, j, timeout;
  *pTWI_FIFO_CTL = 0;        /* clear the bit manually */
          *pTWI_CONTROL = TWI_ENA | PRESCALE_VALUE;                              /* PRESCALE = fsclk/10MHz */
          *pTWI_CLKDIV = ((CLKDIV_HI) << 8) | (CLKDIV_LO);          /* CLKDIV = (1/SCL)/(1/10MHz) */
          *pTWI_MASTER_ADDR = DeviceAddr;                                                            /* target address (7-bits plus the read/write bit) */
          for (i = 0; i < Count; i++)
              /* # of configurations to send */
                    *pTWI_XMT_DATA8 = *TWI_Data_Pointer++;          /* pointer to data */
                    ssync();
                    *pTWI_MASTER_CTL = (TWI_Length<<6) | MEN;          /* start transmission */
                    timeout = 0x1000;
                    for (j = 0; j < (TWI_Length-1); j++)
                        /* # of transfers before stop condition */
                              while ((*pTWI_FIFO_STAT == XMTSTAT) && --timeout)          /* wait to load the next sample into the TX FIFO */           // TAR37913
                                        asm("nop;");
                                        asm("nop;");
                                        asm("nop;");
                                        ssync();
                              if(!timeout)
                                        return;
                              *pTWI_XMT_DATA8 = *TWI_Data_Pointer++;                    /* load the next sample into the TX FIFO */
                              ssync();
                    while ((*pTWI_INT_STAT & MCOMP) == 0)                              /* wait until transmission complete and MCOMP is set */
                              ssync();
                    *pTWI_INT_STAT = XMTSERV | MCOMP;                                        /* service TWI for next transmission */
          asm("nop;");
          asm("nop;");
          asm("nop;");
My question why is function variable RightLineIn a array, not a number and how is it been used in the function.
Thanks for your help
--Neo
