ADSP 21065L SDRAM Controller problem
Question asked by Clementina on Jun 16, 2010
Latest reply on Jun 21, 2010 by vishwanath
I have this unworking scenario on my board with a adsp as in object. In few words the instructions are abnormally modified when placed in external sdram segment.
I attached two files in which you can see, in mixed mode, how the code is disassembled.
In "int_mem.txt" file the cut/pasted code is ok and I can read/write in the external sdram while in "ext_mem.txt" one the code has been placed in pm external memory but it doesn't work properly !
Assuming that the board has been correctly designed, how can I test the DSP to be sure that I have to replace it ?
Note:
seg_pmco { TYPE(PM RAM) START(0x00008200) END(0x000097ff) WIDTH(48) }
pm_sdram { TYPE(PM RAM) START(0x20000) END(0x2fffe) WIDTH(32)  }
// SDRAM Controller Register
ustat1 = 0xA87298FF;
DM(IOCTL) = ustat1;
NOP;
Messaggio modificato da Clementina
