ADAS3022 overvoltage protection, AA Filter, settling spec
Question asked by tonyMC on Nov 20, 2013
Latest reply on Dec 11, 2013 by Ryan_Curran
I have a few questions with regard to the ADAS3022 device.
1. I would like to add over-voltage protection resistor to each multiplexer input. In order to determine the resistor power dissipation can you provide the
    maximum continuous current the multiplexer can tolerate ?
2. If I use the ADAS3022 device at a lower throughput of 100ksps, is it possible to modify the 8Mhz bandwidth of the device for different anti-alias
    response and possibly improved noise performance ? Can a single anti-alias filter be added to the AUX input pins to achieve this ?
3. If the AUX pins are not used should they be left floating ?
4. Can this device settle a full-scale step input to 16-bit accuracy within a single conversion for each of the input voltage ranges ?
Thanks.
