Vrms calibration in ADE7758_SPI with Arduino
Question asked by jianyee92 on Nov 19, 2013
Latest reply on Feb 14, 2014 by dlath
Hi. I am using ADE7758 in my energy monitoring system project. I am able to use SPI to communicate with my Arduino and it is able to display the results. However, I am having some problem calibrating VRMS with the steps given in the ADE7758 datasheet in page 55. By following the steps, I have writen the values into LCYCMODE and MASK like below:
In cpp. file
void ADE7758::setLineCyc(int l)
{    write16 (LINECYC, l);          }
In Arduino Setup
void ADE7758::setMASK(long e)
{    write24 (MASK, e);             }
Then, I followed step  4 by taking N=100,
In cpp file
long ADE7758::Avrms() {
        char i=0;
        long v=0;
        getAVRMS();                                                            //Ignore first reading to avoid garbage
        for(i=0;i<100;++i)
          {    v+=getAVRMS();     }
        return v/100;
long ADE7758::getAVRMS(void) {
        long lastupdate = 0;
        ADE7758::getresetInterruptStatus();                          // Clear all interrupts
        lastupdate = millis();
        while( !  ( ADE7758::getInterruptStatus() & ZXA )  )      // wait Zero-Crossing
        {        // wait for the selected interrupt to occur
                if ( ( millis() - lastupdate ) > 100)
                {       wdt_reset();
                        Serial.println("\n--> getAVRMS Timeout - no AC input");
                        break;
        return read24(AVRMS);
With this code, I am able to produce different values for different input voltage. But the changes are very small.
In order to use the AVRMSOS formula, my readings after using a 10:1 step down transformer:
V_min = 2.5,       V_nom = 24
and the values obtained are as below:
formula for VRMSOS.JPG (formula can be found in pg 55 of datasheet)
So, substituting the value into the formula:
V_in= 5.7V
V_in= 24.5V
V_in= 49V
--> before calibration
VRMS_100: 16767890.0000
--> after calibration
VRMS_100: 1341.5760498046
VRMS_100: 16705047.0000
VRMS_100: 1336.5480957031
VRMS_100: 16693657.0000
VRMS_100: 1335.6367187500
VRMS_100: 16766609.0000
VRMS_100: 1341.4735107421
VRMS_100: 16762652.0000
VRMS_100: 1341.1569824218
VRMS_100: 16506393.0000
VRMS_100: 1320.6540527343
VRMS_100: 16771791.0000
VRMS_100: 1341.8881835937
VRMS_100: 16767304.0000
VRMS_100: 1341.5291748046
VRMS_100: 16777212.0000
VRMS_100: 1342.3218994140
Hence, AVRMSOS = 0x00E (Taking only the last 3 LSB)
The readings obtained are very large. Does this have to do with the VRMSGAIN? I have not written any values into the VRMSGAIN. May I know how can I obtain the correct value of VRMSGAIN?
The connectivity for the circuit is as below:
Much of the codes are refered from this link: https://code.google.com/p/ardugrid7753/source/browse/#svn%2Ftrunk
Thank you.
