ADXL345 Configuration
Question asked by Cjp3323 on Nov 19, 2013
     I'm using the ADXL345 for a project and am having trouble writing to the registers. I attempt to write to the the Data format reg followed by a write to the power ctl register. I then read back the values of these registers and display them to my terminal in which case a '0' appears meaning they are still at there reset values and not the ones I wrote. I have confirmed that I can in fact read a register appropriately as I have done it successfully with the device ID register. My function for writing to a register is:
#define ACCEL_W 0xA6
#define ACCEL_R 0xA7
void writeAccelReg(char reg, char byte)
    StartI2C3();
    IdleI2C3();
    MasterWriteI2C3(ACCEL_W);
    IdleI2C3();
    MasterWriteI2C3(reg);
    IdleI2C3();
    MasterWriteI2C3(byte);  //byte is the data to be stored in the reg
    IdleI2C3();
    StopI2C3();
and for reading a reg is:
char readAccelReg(char reg)
    char byte;
    StartI2C3();
    IdleI2C3();
    IdleI2C3();
    IdleI2C3();
    RestartI2C3();
    IdleI2C3();
    MasterWriteI2C3(ACCEL_R);
    IdleI2C3();
    byte = MasterReadI2C3();
    NotAckI2C3();
    IdleI2C3();
    StopI2C3();
    return byte;
     I'm using a PIC24 and the schematic setup is attached. It's a breakout board from sparkfun used by many so the hardware should be configured correctly. The I2C lines also seem to be set up correctly since I can do successful read operations. I have also confirmed that no I2C errors occur during transmissions. I understand this is a very simple procedure which is why it's so bothersome in the first place. Ultimately, I would like confirmation that the software "should" in fact work so that I can focus on seeing if there's something wrong with the board and if I need to order another one. Let me know if you need any other relevant information.
Caleb
