spi sd card (mmc_spi) in 2013R1
Question asked by illishar on Nov 19, 2013
Latest reply on Nov 27, 2013 by illishar
We have an micro sd card attached to our spi0, cs 3. We cannot make it work in Linux though. It seems to work fine in u-boot.
Kernel message is:
... mmc_spi spi0.3: ASSUMING 3.2-3.4 V slot power mmc_spi spi0.3: setup: unsupported mode bits 4 mmc_spi spi0.3: can't change chip-select polarity mmc_spi spi0.3: SD/MMC host mmc0, no DMA, no WP, no poweroff ... mmc0: card lacks mandatory switch function, performance might suffer. ... mmc0: host does not support reading read-only switch. assuming write-enable. ------------[ cut here ]------------ WARNING: at drivers/mmc/core/core.c:990 Modules linked in:   CPU: 0 PID: 8 Comm: kworker/u2:1 Not tainted 3.10.10-ADI-2013R1-svn9708 #95 Workqueue: kmmcd _mmc_rescan task: 0103dac0 ti: 01048000 task.ti: 01048000 ADSP-BF516-0.2 300(MHz CCLK) 100(MHz SCLK) (mpu off) Linux version 3.10.10-ADI-2013R1-svn9708 (mk@PCHe-Ubuntu) (gcc version 4.3.5 (ADI-2011R1-RC4) ) #95 Tue Nov 19 11:00:21 CET 2013   SEQUENCER STATUS:               Not tainted  SEQSTAT: 00002021  IPEND: 8008  IMASK: ffff  SYSCFG: 0006   EXCAUSE   : 0x21   physical IVG3 asserted : <0xffa00650> { _trap + 0x0 }   physical IVG15 asserted : <0xffa00dc8> { _evt_system_call + 0x0 }   logical irq   6 mapped  : <0xffa00290> { _bfin_coretmr_interrupt + 0x0 }   logical irq  27 mapped  : <0x000fa27c> { _bfin_twi_interrupt_entry + 0x0 }   logical irq  35 mapped  : <0x000f4ecc> { _bfin_mac_interrupt + 0x0 }  RETE: <0x00000000> /* Maybe null pointer? */  RETN: <0x01049ddc> /* kernel dynamic memory */  RETX: <0x00000480> /* Maybe fixed code section */  RETS: <0x00100d00> { _mmc_sd_init_card + 0xd4 }  PC  : <0x000fb042> { _mmc_set_clock + 0xa } DCPLB_FAULT_ADDR: <0x015538c0> /* kernel dynamic memory */ ICPLB_FAULT_ADDR: <0x000fb042> { _mmc_set_clock + 0xa } PROCESSOR STATE:  R0 : 00061a80    R1 : 00000000    R2 : 00000058    R3 : 00000000  R4 : 00000000    R5 : 0103ca05    R6 : 00000000    R7 : 00000000  P0 : 0000194c    P1 : 01553800    P2 : 001fa988    P3 : 01553800  P4 : 01049df0    P5 : 01553400    FP : 01038e00    SP : 01049d00  LB0: 000c7c86    LT0: 000c7c86    LC0: 00000000  LB1: 000c65a0    LT1: 000c6594    LC1: 00000000  B0 : 0000005c    L0 : 00000000    M0 : 00000010    I0 : 001fb4d4  B1 : 0016ff50    L1 : 00000000    M1 : 00000007    I1 : 001e7b04  B2 : 0017f898    L2 : 00000000    M2 : 00001802    I2 : 001e6130  B3 : 00000000    L3 : 00000000    M3 : 0000005b    I3 : 00000057 A0.w: 00000000   A0.x: 00000000   A1.w: 00000000   A1.x: 00000000 USP : 00000000  ASTAT: 02002062   ---[ end trace 63bc9a61e7067c0b ]--- Hardware Trace:    0 Target : <0x00003dbc> { _trap_c + 0x0 }      Source : <0xffa005e4> { _exception_to_level5 + 0xa4 } CALL pcrel    1 Target : <0xffa00540> { _exception_to_level5 + 0x0 }      Source : <0xffa003f8> { _bfin_return_from_exception + 0x18 } RTX    2 Target : <0xffa003e0> { _bfin_return_from_exception + 0x0 }      Source : <0xffa0049a> { _ex_trap_c + 0x72 } JUMP.S    3 Target : <0xffa00428> { _ex_trap_c + 0x0 }      Source : <0xffa006aa> { _trap + 0x5a } JUMP (P4)    4 Target : <0xffa00650> { _trap + 0x0 }       FAULT : <0x000fb042> { _mmc_set_clock + 0xa } BUG      Source : <0x000fb040> { _mmc_set_clock + 0x8 } IF !CC JUMP pcrel (BP)    5 Target : <0x000fb038> { _mmc_set_clock + 0x0 }      Source : <0x00100cfc> { _mmc_sd_init_card + 0xd0 } CALL pcrel    6 Target : <0x00100cfa> { _mmc_sd_init_card + 0xce }      Source : <0x00100dc0> { _mmc_sd_init_card + 0x194 } JUMP.S    7 Target : <0x00100dba> { _mmc_sd_init_card + 0x18e }      Source : <0x00100cf4> { _mmc_sd_init_card + 0xc8 } IF CC JUMP pcrel (BP)    8 Target : <0x00100cee> { _mmc_sd_init_card + 0xc2 }      Source : <0x00100d9a> { _mmc_sd_init_card + 0x16e } JUMP.S    9 Target : <0x00100d96> { _mmc_sd_init_card + 0x16a }      Source : <0x00100ce6> { _mmc_sd_init_card + 0xba } IF CC JUMP pcrel   10 Target : <0x00100ce2> { _mmc_sd_init_card + 0xb6 }      Source : <0x001003bc> { _mmc_sd_switch_hs + 0x8c } RTS   11 Target : <0x001003b2> { _mmc_sd_switch_hs + 0x82 }      Source : <0x0010034c> { _mmc_sd_switch_hs + 0x1c } IF CC JUMP pcrel   12 Target : <0x00100330> { _mmc_sd_switch_hs + 0x0 }      Source : <0x00100cde> { _mmc_sd_init_card + 0xb2 } CALL pcrel   13 Target : <0x00100cd0> { _mmc_sd_init_card + 0xa4 }      Source : <0x00100528> { _mmc_sd_setup_card + 0x60 } RTS   14 Target : <0x00100520> { _mmc_sd_setup_card + 0x58 }      Source : <0x0010073a> { _mmc_sd_setup_card + 0x272 } JUMP.S   15 Target : <0x00100738> { _mmc_sd_setup_card + 0x270 }      Source : <0x0016dd32> { _printk + 0x26 } RTS mmc0: new SD card on SPI ... Nov 20 12:00:51 kernel: mmc_spi spi0.3: setup: unsupported mode bits 4 ...
Our board files contains the following:
#if defined(CONFIG_MMC_SPI) || defined(CONFIG_MMC_SPI_MODULE) static struct bfin5xx_spi_chip mmc_spi_chip_info = {           .enable_dma = 0, }; #endif  #if defined(CONFIG_MMC_SPI) || defined(CONFIG_MMC_SPI_MODULE)           {                     .modalias = "mmc_spi",                     .max_speed_hz = 25000000,     /* max spi clock (SCK) speed in HZ */                     .bus_num = 0,                     .chip_select = 3,                     .controller_data = &mmc_spi_chip_info,                     .mode = SPI_MODE_3,           }, #endif
We've tried both with the 2010 and the newest 2013r1 Linux. Same thing. We've tried another sd card. Different error, but still no luck. The sd card that's currently attached is working fine on another board that uses the Blackfin SDH.
What are we doing wrong?
