AD5622 Linux drivers
Question asked by HankZ on Nov 15, 2013
Latest reply on Nov 18, 2013 by mdelong20
I have a single board computer that I am designing that has your nano-DAC P/N
AD5622.  I am building Linux with the help your your wiki guide.  I found this page/driver
(https://wiki.analog.com/resources/tools-software/linux-drivers/iio-dac/ad5446)
which seems to support my part.  I included this in the Kernel build (I can see
it under /sys/bus/iio/drivers) so I know its here.  The issue is when the device boots, it doesn't find the  device.
I get an error:ad5446: probe of 0-000f failed with error -22 (The device is set to address 0x0F).
I can interface to the device using the normal i2c built in commands (i2cget/i2cset).
I can set the voltage to half range using the command:
i2cset 0 0x0F 0x07 0xFc I can verify the change and value with a scope.
So based on that, I think its working ok at least in the physical connection.
I am using this entry in my device tree:
/* Analog Devices AD5622 DAC */
dac: hv-control@0F {compatible = "adi,ad5622";reg = < 0x0F >;};This entry is under my main i2c driver entry.  I also have 4 other sensors defined in this region that work.Is there some issue there?  Can you suggest a better device tree entry.
