Trouble reading from the flash.
Question asked by dinrail on Nov 12, 2013
Latest reply on Nov 14, 2013 by dinrail
if I read the flash with the following codes in main(), it works
char key[64];
flashAddress = ( unsigned long *)EE_KEY;
    pArray =( unsigned long *)key;
    for (i = 0; i < 16; i = i+4)
*pArray++ = *flashAddress++;
but since I read the flash in different part of the program, so I'd like to use a more general routine to read it, so I use a function ReadFromFlash
void ReadFromFlash(unsigned long *pArray, unsigned long ulStartAddress, unsigned int uiSize)
    volatile unsigned long *myflashAddress;
    unsigned long * mypArray;
    unsigned int i = 0;
    myflashAddress = ( unsigned long      *)ulStartAddress;
    mypArray=( unsigned long      *)pArray;
    for (i = 0; i < uiSize; i = i+4)
        *mypArray++ = *myflashAddress++;
and try to read the same block using
ReadFromFlash((unsigned long*) key, (unsigned long)EE_KEY,16);
but the program hangs
So I placed a break point at *mypArray++ = *myflashAddress++; inside ReadFromFlash
and reset and run the program again, when the program stopped at the break point, if I hit F5 to resume, the program will hang at line 140 of C:\Keil\Analog\common\startup_ADuCM360.s. but if I hit F10 (step over) four times, the program will run without any glitch.
if I change char key[64]; to unsigned long key[64]; it works fine, too (please note that I am only reading 16 bytes)
Any idea on what can cause this? (the same codes work fine when placed in main())
