What is the scope of pragma optimize commands?
Question asked by Ribred on Nov 7, 2013
Latest reply on Nov 8, 2013 by CraigG
The VDSP++ 5.0 C Compiler manual says on page 1-204
"General Optimization Pragmas
The compiler supports several pragmas which can change the optimization
level while a given module is being compiled. These pragmas must be used
globally, immediately prior to a function definition. The pragmas do not
just apply to the immediately following function; they remain in effect
until the end of the compilation, or until superseded by one of the following
optimize_ pragmas...."
A colleague reviewing my code is concerned about ambiguity as to scope of this pragma.  I say any pragma such as optimize_off only applies within a single file since the manual says it applies to a given module.  Therefore I issue a optimize_off at the start of a file related to hardware when I want no optimization then assume other code modules ( *.c, h etc files) will be optimized as command line by default.  He isn't sure.
I tried to add pragma optimize_as_cmd_line at the end of the file but since it doesn't precede a function it gives warnings.
.\BSP\kvh_config.c
".\BSP\kvh_config.c", line 471: cc0606: {D} warning: this pragma must
          immediately precede a declaration
  #pragma optimize_as_cmd_line
Questions:
1) Does this pragma have module scope only or does it continue to apply to other modules compiled after the one containing it?
2) (I don't want to do this if I don't have to but...) should every file have a pragma optimize_as_cmd_line to make it unambiguous?
Thanks.
