Strange behaviour modulo operation
Question asked by ChristianH on Nov 4, 2013
Latest reply on Nov 5, 2013 by ChristianH
I'm a little confused about modulo operation but maybe there is a stupid simple answer that I don't see at the moment.
I use a ADSP-21469 programmed with VisualDSP++ 5.0 Update 10.1 in "C".
I tried to do a modulo operation but failed with a result of 0 all the time.
Following I've tested:
#define NUM_SAMPLES 0x10000
tempsize = TOC.Data[n].length % NUM_SAMPLES; ==> result is always 0
ASM-Code:
[08E4FE] r2=fext r2 by 0:0x6;
[08E4FF] r2=lshift r2 by 0xa;
but if I replace the NUM_SAMPLES by it's value:
tempsize = TOC.Data[n].length % 0x10000; ==> correct result
ASM-Code:
[08E4FE] r2=fext r2 by 0:0x10;
In my opinion the first code can not work correctly.
At another code location I've also used a modulo operation and the result was
[08D6A7] cjump ___uldiv(db)
giving me also the correct result (modulo value is 0x5A).
Any ideas?
Thanks
Christian
