ADuC7129 PWM
Question asked by jakpil on Oct 31, 2013
Latest reply on Dec 4, 2013 by MMA
I want to use all 6 PWM outputs in uC separately to generate impulse 1ms- 2ms with period of 20ms. I calculated everything and get correct values. Problem is that to achieve six completely separate outputs I must reverse all outputs. My question is : Is bit 5 (POINV) i register PWMCON1 work correctly? In my code changing the bit doesn't change output polarity.
GP3CON &= ~(0xF << (PWM1 << 2));
GP3CON &= ~(0xF << (PWM2 << 2));
GP3CON &= ~(0xF << (PWM3 << 2));
GP3CON &= ~(0xF << (PWM4 << 2));
GP3CON &= ~(0xF << (PWM5 << 2));
GP3CON &= ~(0xF << (PWM6 << 2));
GP3CON |= (1U << (PWM1 << 2));
GP3CON |= (1U << (PWM2 << 2));
GP3CON |= (1U << (PWM3 << 2));
GP3CON |= (1U << (PWM4 << 2));
GP3CON |= (1U << (PWM5 << 2));
GP3CON |= (1U << (PWM6 << 2));
PWM1LEN = SERVO_PERIOD; //20ms
PWM2LEN = SERVO_PERIOD;
PWM3LEN = SERVO_PERIOD;
PWM1COM3 = SERVO_MAX;
PWM1COM2 = 5222;
PWM1COM1 = 5222 + SERVO_MAX;
PWM2COM3 = SERVO_MAX;
PWM2COM2 = 5222;
PWM2COM1 = 5222 + SERVO_MAX;
PWM3COM3 = SERVO_MAX;
PWM3COM2 = 5222;
PWM3COM1 = 5222 + SERVO_MAX;
//     PWMCON1 = 0x38E1;
PWMCON1 = 0x38E1;
This code should generate 1ms impulse witch period 20ms on all 6 outputs.
