BF592: non-blocking SPORT mode - burst transmission?
Question asked by Chrill on Oct 29, 2013
Latest reply on Nov 6, 2013 by randreol
Hi all,
I'm using BF592 (ez-kit) with cces 1.0.2.
I'm currently kind of struggling with a seemingly simple talkthrough problem:
+ I'm reading ADC data via SPI
+ each SPI read (BF592 is master) is triggered by a timer IRQ
+ on every 4th timer IRQ I need to send data via SPORT to a DAC (2 x 3 bytes) - possibly with a high bitclock frequency
So basically what I'd like to do is bursting out some data on the SPORT - triggered by a timer IRQ.
What I did was this (I removed the less important parts for clarity):
bool timerFlag = false;
int channel = 1;
static void TimerHandler(void *pCBParam, uint32_t Event, void *pArg) {
          switch (Event) {
               case ADI_TMR_EVENT_IRQ:
                              timerFlag = true;
                              break;
               default:
                              break;
int main(void)
     uint8_t TxBuffer[2]  = {WRITE_CFR_DUMMY_LO,MANUAL_CHANNEL_ENBL};
     uint8_t RxBuffer[2]  = {0u,0u};
     ADI_SPI_TRANSCEIVER Transceiver1  = {NULL, 0u, &TxBuffer[0], 2, &RxBuffer[0], 2};
     uint8_t sportBuffer_li[SIZE_OF_TX_BUFFER] = {0x00, 0x00, SPORT_pre_li};
     uint8_t sportBuffer_re[SIZE_OF_TX_BUFFER] = {0x00, 0x00, SPORT_pre_re};
     /*setup SPI*/
     /*setup timer*/
     /*setup SPORT*/
     adi_sport_Open(0,ADI_SPORT_DIR_TX, ADI_SPORT_SERIAL_MODE, DeviceMemory,ADI_SPORT_DMA_MEMORY_SIZE,&hSPORTdevice);
     adi_sport_ConfigData(hSPORTdevice, ADI_SPORT_DTYPE_ZERO_FILL, false, 23u);
     adi_sport_ConfigClock(hSPORTdevice, 1u, true, bFallingEdge);
     adi_sport_ConfigFrameSync(hSPORTdevice, 24u, true, true, bDataIndi, bActiveLow, false);
     adi_sport_EnableDMAMode(hSPORTdevice,false);
     while(1){
          if (timerFlag){
               adi_spi_ReadWrite(hSPIdevice, &Transceiver1);
               switch (channel){
                    case 1:
                           sportBuffer_li[0] = RxBuffer[0];
                           sportBuffer_li[1] = RxBuffer[1];
                           break;
                     case 2:
                           sportBuffer_re[0] = RxBuffer[0];
                           sportBuffer_re[1] = RxBuffer[1];
                           break;
                     case 3:
                           /*ignore data of channel 3*/
                          break;
                     case 4:
                          /*ignore data of channel 4*/
                          break;
               if(channel==4){
                   adi_sport_Enable(hSPORTdevice,false);
                   adi_sport_SubmitBuffer(hSPORTdevice,sportBuffer_li,SIZE_OF_TX_BUFFER);
                   adi_sport_SubmitBuffer(hSPORTdevice,sportBuffer_re,SIZE_OF_TX_BUFFER);
                   adi_sport_Enable(hSPORTdevice,true);
               channel++;
               if (channel==5){
                  channel = 1;
               timerFlag = false;
In principle this code works - the problem is that disabling/enabling the SPORT for each transfer takes too long such that the code block in
if (timerFlag)
cannot be processed in time, i.e. a new timer IRQ is already pending.
Is there a better way to implement burst transmission via SPORT (I wouldn't even care if the SPORT clock was running all the time)?
Can I somehow use adi_sport_GetBuffer() to get pointers to the SPORT buffers even if they are both empty?
Any hints are much appreciated!
Chris
