Precision Clock Generator Frame Sync Inversion
Question asked by alemannia on Oct 29, 2013
Latest reply on Oct 29, 2013 by alemannia
I am trying to configure the PCGs to provide clock and frame sync signals for different SPORT channels. Here is my setup so far:
MCLK (24.576 MHz)
    |     PCG_A ( AUDIO )
    +--->| /4   = 6.144 MHz |--> CLK_A
    +--->| /256 = 96 kHZ    |--> FS_A
    |     PCG_B ( COM )
    +--->| /1  = 24.576 MHz |--> CLK_B
    +--->| /64 = 384 kHz    |--> FS_B
Both PCGs are generating clock signals for left-justified SPORT transmission. In order for this to work the generated FS and CLK signals must be phase reversed. Meaning that a rising edge of FS happens on a falling edge of CKL. I have managed to achieve this on PCG A by adding a phase shift to the FS signal:
                            _   _  |_   _   _   _   _   _   _   _
  CLKIN (24.576 MHz)      _| |_| |_| |_| |_| |_| |_| |_| |_| |_| |_
                          _        |_______         _______
  CLK_A                    |_______|       |_______|       |___
                                   |_________________________________
  FS_A (PHASE 0)          _________|
                            _______|________________________
  FS_A (PHASE 2)          _|       |
As the clock divider of PCG B is 1 I have no possibility to play with the phase shift between CLK/FS. It will always be the same.
  CLK_B                   _| |_| |_| |_| |_| |_| |_| |_| |_| |_| |_
  FS_B (PHASE 0)          _________|
                                ___|_________________________________
  FS_B (PHASE 1)       ________|
Is there another way of inverting the FS signal on PCG B?
I have tried:
> Change the functionality of FS and CLK by setting the CLK divider to 64 and the FS divider to 1 (bypass), then enabling the INVERTB bit, but the SRU won't let me connect PCG_FS_O to SPORT_CLK_I .
> Has a look into the MISC buffers which have the possibility of inverting signals but their outputs can only be used as pin enable inputs.
Any other ideas?
