Demonstrating "call-back concept" in CCES
Question asked by MikeSmithCanada on Oct 28, 2013
Latest reply on Nov 18, 2013 by MikeP
Hi
I am trying to demonstrate the concept of a call-back function in C++ in CCES
I am seitting up the interrupt as a void func(void)
and can get the pointer code working
void (*p2Function) void =  &IamISR;
I can set up a pointer to the IVTMR address in EVB
if I use volatile int ( syntax -- but then I have to cast the function pointer to an int
I can't persuade the pIVTMR address to point to a void function pointer.  Any idea of the correct syntax?
Question 2 -- Does CCES support some form of Ssync( ) function without me having to switch into assembly code to do it
Thanks
Mike
#include <blackfin.h>
#include <stdio.h>
#define SSYNC() asm("ssync;")     // Is there not a CCES-defined  C++ call that does this?
volatile unsigned int countISR = 0;
// Will discuss in class why most CallBack are of the form void CallBack(void *)
void CallBack(void) {
    countISR++;
    SSYNC();
#pragma interrupt;
void IamISR(void) {
    *pTCNTL &= 0x7;          // The idea is show impact of using pragma inline
    SSYNC();
    CallBack( );
int main(void)
    *pTCNTL = 0;
    *pTCOUNT = 0x400000;
    *pTPERIOD = 0x400000;
    *pTSCALE = 0;
    SSYNC();
    void (*pt2Function)(void) = NULL;   // Declaring a function pointer
    pt2Function = &IamISR;               // And pointing to ISR
// Since CCES does not have the equivalent of register_handler
//    and I wanted to expose what is happening inside a ISR handler
//    with Callback function, I had to define the equivalent
// However, I wanted pIVTMR to be defined to point to a void (*pt2Function)(void)
// but I could not find the correct syntax to define a void * pointer to access MMR
// and use the same pointer to point to void (*pt2Function)(void)
    volatile int *pIVTMR =  (volatile int *) ( 0xFFE02018);
    *pIVTMR = (int) pt2Function;
    countISR = 0;
    *pIMASK |= 0x40;
    *pTCNTL = 7;
    SSYNC();
    printf("Starting\n");
    while (countISR< 8) /* Do nothing */ ;
    printf("Done\n");
    *pTCNTL = 0;
    SSYNC();
    return 0;
