ADV7513 output works on some monitors but not others
Question asked by vasikri on Oct 28, 2013
Latest reply on Oct 30, 2013 by GuenterL
I'm using the ADV7513 to output 720p video over HDMI.
So far all I'm doing is making a test pattern in my FPGA and sending it to the ADV7513. I have it to the point where it shows me the test pattern on some monitors however on other monitors I get misaligned images or no image at all (Monitor reports "No Signal Found"). I know these other monitors also support 720p video (and higher). Some of them are DVI input monitors for which I use a HDMI to DVI cable. I tried swapping the DVI bit (Reg 0xAF[1]) but it didn't help the cause of lining up the image, though it did clear up some fine horizontal line artifacts.
I'm using the following timing:
Horizontal: 1650 pixels/row
Vertical: 750 rows/frame
Active Horizontal pixels: 1280
Active Rows: 720
I am using external syncs. My DE is aligned with active data.
The ADV7513 registers are set to the following values:
0x41 = 0x10
0xD6 = 0xC0
0x98 = 0x03
0x9A = 0xE0
0x9C = 0x30
0x9D = 0x61
0xA2 = 0xA4
0xA3 = 0xA4
0xE0 = 0xD0
0xF9 = 0xD0
0x15 = 0xF0
0x16 = 0x30
0x17 = 0x02
0x18 = 0x46
0xAF = 0x06
0x97 = 0x40
0x01 = 0x00
0x02 = 0x18
0x03 = 0x00
0x0A = 0x00
0x0B = 0x0E
0x0C = 0xC0
What is the prescribed timing for H/V sync transitions within the frame? I wasn't able to find a specific recommendation in the ADV7513 documentaiton but perhaps I just missed it. Please help.
Vivek
